Hello I am having a trouble with join operation in Arcgis pro 2.7.0. I created two raster data with common columns which I executed join field by choosing them. They are both fine in different layers and seems no mistake. However after I joined those two tables the areas in the new map do not seem in the correct location when I chose Select by attiributes. I went through the same process twice but still cant figure out what is wrong. I would really appreciate if you help me. Thanks in advance.
