Hi, do you know a way how i can get OSM Relations with all the Attributes in Arcmap.
I see all the Attributes in JOSM but i can only export them as GPX and after that i lost all the OSM Tags. Is there any way to get this Data into Arcmap?
Thank You!
I wonder if the Data Interoperability extension for ArcMap would be able to import the data in a shapefile or geodatabase feature class? OSM is a supported read-only format in the extension.
I will try this, but i can already load OSM Files with the "ArcGIS Editor for OSM 10.8.x Desktop" do you think the Data Interoperability will Load it different?
The Data Interoperability extension will convert it from a non-Esri format to a geodatabase feature class so it's different.
