Non http links generated in Arcade (e.g. flow:// which triggers the Flowfinity app installed on the device) do not work in Field Maps on iOS or Android - they display the text but are not clickable.
The same URL works in a standard web map on both platforms, and in Collector and Explorer on iOS, but not on Android.
The same link set up without using Arcade (custom popup) does work on all platforms.
Any indication when Arcade links will be supported in Field Maps?
