Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Startseite
Produkte
ArcGIS Pro
ArcGIS Pro Ideas
Change the direction-distance tool to geographic angles instead of arithmetic angles
ChrisStarbird1
The way it is now, the direction-distance tool in the editor toolbar (little circle with a line through it) uses arithmetic angles instead of geographic angles (ie azimuth). This seems silly to me because ArcGIS is a
geographic
information system. It seems far more likely that I would be using the direction-distance tool to calculate an offset based on a compas heading (azimuth) and distance. Instead, I have to first convert the azimuth to and arithmetic angle... which is a total drag. At least give me the option to choose between the two angle systems!
Finde mehr Beiträge mit dem Tag
Status: Öffnen
Kommentare
Chris Fox
Thank you for posting your idea, you can set this from Editor > Options > Units. The default direction type is Polar, but you could set it to North or South Azimuth based on your needs. More information on this is available in the help topics below:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/About_direction_measuring_systems_and_units/001t00000009000000/
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Setting_the_direction_type_and_units_used_when_editing/001t0000000m000000/
Nehmen Sie an der Diskussion teil
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
Anmelden
Registrieren
Schnellzugriffe
Alle Communities
Neueste Beiträge
Benutzergruppen
Gefolgte Inhalte
Community-Hilfe
