public void FindDifferences(IWorkspace ws, List<string> tableNames) { try { // Searching for insert differences foreach (string tableName in tableNames) FindDiff(ws, tableName); } catch (Exception ex) { //Logging } } public void FindDiff(IWorkspace workspace, string tabName) { IVersionedWorkspace versionedWorkspace = (IVersionedWorkspace)workspace; IVersion childVersion = versionedWorkspace.DefaultVersion; IVersion parentVersion = versionedWorkspace.FindVersion("MY_VERSION"); // Cast to the IVersion2 interface to find the common ancestor. IVersion2 childVersion2 = (IVersion2)childVersion; IVersion commonAncestorVersion = childVersion2.GetCommonAncestor(parentVersion); // Cast the child version to IFeatureWorkspace and open the table. IFeatureWorkspace childFWS = (IFeatureWorkspace)childVersion; ITable childTable = childFWS.OpenTable(tabName); // Cast the common ancestor version to IFeatureWorkspace and open the table. IFeatureWorkspace commonAncestorFWS = (IFeatureWorkspace)commonAncestorVersion; ITable commonAncestorTable = commonAncestorFWS.OpenTable(tabName); IVersionedTable versionedTable = (IVersionedTable)childTable; IDifferenceCursor differenceCursor = versionedTable.Differences(commonAncestorTable, esriDifferenceType.esriDifferenceTypeInsert, null); // Create output variables for the IDifferenceCursor.Next method. IRow differenceRow = null; int objectID = -1; // Step through the cursor, showing the ID of each modified row. differenceCursor.Next(out objectID, out differenceRow); while (objectID != -1) { differenceCursor.Next(out objectID, out differenceRow); ReleaseObject(differenceRow); } ReleaseObject(differenceCursor); ReleaseObject(commonAncestorTable); ReleaseObject(versionedTable); } public static void ReleaseObject(object comObj) { try { if (comObj != null) { System.Runtime.InteropServices.Marshal.ReleaseComObject(comObj); } } catch { } }
Hi Harrison,
I am implementing the same thing in JAVA. I have implemented same code you quoted above both JAVA and .NET. I could able to get correct results in .NET. However, I am not getting any results in JAVA. Below is my code in JAVA. Could you please help me out.
IVersionedWorkspace versionedWorkspace = new VersionedWorkspace(workspace);
IVersion childVersion = versionedWorkspace.findVersion("SDE.Test");
IVersion parentVersion = versionedWorkspace.getDefaultVersion();
IVersion2 childVersion2 = new IVersion2Proxy(childVersion);
commonAncestorVersion = childVersion2.getCommonAncestor(parentVersion);
IFeatureWorkspace childFWS = new IFeatureWorkspaceProxy(childVersion);
ITable childTable = childFWS.openTable(tableName);
commonAncestorFWS = new IFeatureWorkspaceProxy(commonAncestorVersion);
commonAncestorTable = commonAncestorFWS.openTable(tableName);
// Cast to the IVersionedTable interface to create a difference cursor.
IVersionedTable versionedTable = new IVersionedTableProxy(childTable);
differenceCursor = versionedTable.differences(commonAncestorTable, esriDifferenceType.esriDifferenceTypeInsert, null);
int countChildRecords = childTable.rowCount(null);
int countParentRecords = commonAncestorTable.rowCount(null);
// Create output variables for the IDifferenceCursor.Next method and a FID set.
IFIDSet fidSet = new FIDSet();
IRow[] differenceRow = null;
int[] objectID = null;
differenceCursor.next(objectID, differenceRow);
Thanks & Regards,
Vara Prasad.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
