Please add a widget to ArcGIS Online Web Appbuilder to enable a user to enter an XY coordinate and then GO TO that coordinate or make it flash or label it, like in the ArcGIS Desktop software.
David Wheelock the eLocate widget by Robert Scheitlin, GISP does this - https://community.esri.com/docs/DOC-7046
Thank you Kevin. I already checked out Robert's nice tool month's ago, but it can only be used in Portal. It cannot be used in ArcGIS Online which doesn't allow that sort of customization. ESRI doesn't allow it because of the potential to inject malware into the ArcGIS Online environment.
David, yes indeed. In that case, thanks and I agree; I voted for your idea.
This is the same as this idea I posted a while ago: https://community.esri.com/ideas/11495. These two should be merged together. ESRI, feel free to take mine down and add the votes to this one.
Thanks. I don't know how ESRI goes about combining ideas into a single idea. ESRI?
Please try the Search widget. If you have configured the Esri World Geocoding Service as the search source, you can search by coordinates in the following ways:
More details can be found here: Search widget—Web AppBuilder for ArcGIS | ArcGIS, and findAddressCandidates—ArcGIS REST API: World Geocoding Service | ArcGIS for Developers .
Hi Lemao,
Yes, your suggestion works fine, however this is not a easy to use or intuitive way to work with go to XY. It is such a simple tool that would make it much simple for non-map nerds to undersand. Now all need to understand x before y and then the current ?WKID?... It is perhaps a simple workaround for us that live and breathe map technology. However I had a feeling that one of the most important use cases for the Portal and Web Appbuilder was to make it easy not to be a GIS wizzard.
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
