Now I cannot do that. I need to change schema name (schema.tablename) in big set of symbolized layers. Repair datasource of course doesn't work, definition query is different thing as well. I realized that I can't automate my task with arcpy.
This is possible using ArcGIS Pro version 3.2. In the Updating Data Sources help topic, go to the CIM Section, and check out the third code sample:
# Reference project, map and layer p = arcpy.mp.ArcGISProject(r'C:\Projects\USA.aprx') m = p.listMaps('USA')[0] l = m.listLayers('States')[0] # Get the layer's CIM definition lyrCIM = l.getDefinition('V3') # Update the sql query where clause for the layer sql = lyrCIM.featureTable.dataConnection.sqlQuery newsql = sql.replace("WHERE SUB_REGION = 'Mtn'", "WHERE SUB_REGION = 'Pacific'") lyrCIM.featureTable.dataConnection.sqlQuery = newsql # Set the layer's CIM definition l.setDefinition(lyrCIM)
The above sample changes the sql query, but other properties of the Query Layer can also be updated.
A fix was made in Pro 3.2 that enables modifying query layers via Python CIM Access. We will post a sample to this page.
None that I know of.
Is there any update on this idea with python 3.x that is shipped with Pro?
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
