<\/HEAD>
Ich habe einen Attributausdruck, der in einem Popup verwendet wird, das in einer ArcGIS-Webkarte angezeigt wird, aber nicht in einer Web-App oder im Collector.<\/P>
<SPAN class="keyword token">var<\/SPAN> relatedData <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">FeatureSetByName<\/SPAN><SPAN class="punctuation token">(<\/SPAN>$datastore<SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"RelatedData"<\/SPAN><SPAN class="punctuation token">)<\/SPAN>
<SPAN class="keyword token">var<\/SPAN> filteredRelatedData <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">Filter<\/SPAN><SPAN class="punctuation token">(<\/SPAN>relatedData<SPAN class="punctuation token">,<\/SPAN> <SPAN class="token function">Concatenate<\/SPAN><SPAN class="punctuation token">(<\/SPAN><SPAN class="string token">"id="<\/SPAN><SPAN class="punctuation token">,<\/SPAN> $feature<SPAN class="punctuation token">.<\/SPAN>id<SPAN class="punctuation token">)<\/SPAN><SPAN class="punctuation token">)<\/SPAN>
<SPAN class="keyword token">var<\/SPAN> orderedFilteredRelatedData <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">OrderBy<\/SPAN><SPAN class="punctuation token">(<\/SPAN>filteredRelatedData<SPAN class="punctuation token">,<\/SPAN> <SPAN class="string token">'date DESC'<\/SPAN><SPAN class="punctuation token">)<\/SPAN>
<SPAN class="keyword token">var<\/SPAN> newest <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">First<\/Span><span class="punctuation token">(<\/span>orderedFilteredRelatedData<span class="punctuation token">)<\/span>
<span class="keyword token">if<\/span> <span class="punctuation token">(<\/span><span class="token function">IsEmpty<\/span><span class="punctuation token">(<\/span>newest<span class="punctuation token">)<\/span><span class="punctuation token">)<\/span> <span class="punctuation token">{<\/span>
<span class="string token">"n\u002Fa"<\/span>
<span class="punctuation token">}<\/span>
<span class="keyword token">else<\/span> <span class="punctuation token">{<\/span>
<span class="keyword token">var<\/span> installDate <span class="operator token">=<\/span> newest<span class="punctuation token">.<\/span>date
newest<span class="punctuation token">.<\/span>name <span class="operator token">+<\/span> <span class="string token">" ("<\/span> <span class="operator token">+<\/span> <span class="token function">Text<\/span><span class="punctuation token">(<\/span>installDate<span class="punctuation token">,<\/span> <span class="string token">"Y-MM-DD HH:mm:ss"<\/span><span class="punctuation token">)<\/span> <span class="operator token">+<\/span> <span class="string token">")"<\/span>
<span class="punctuation token">}<\/span><span class="line-numbers-rows"><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span><span><\/span></span><\/P>
Ich habe mich bereits damit abgefunden, dass dies im ArcGIS Collector nicht funktioniert. Und jetzt scheint es, dass dies auch in einer Web-App nicht funktioniert. Das ist wirklich frustrierend.<\/P>
<\/P>
Ich suche jedoch nach einer Webseite oder einem Dokument, das Arcade-Einschränkungen über alle ESRI-Produkte hinweg auflistet. Irgendwelche Ideen, wo ich so etwas finden kann?<\/STRONG><\/P><\/P><SPAN style=\
