Hi,I'm fairly new to Business Analyst. I created a custom report based on a trade area. The report runs without error and the fields the I selected show up just fine. However, a map never shows up in the report. I tried using standard reports also and still no map. Does anyone know why a map image is not showing up?Thanks for your help.
Which custom report template are you working with?
I am using the Area Brief Report Template. I can see the placeholder for the map image in the template but when I run the report no map is added.
Can you preview it in the Advanced Editor and see the map insert? If not I would try removing the map completely and then insert a new section below your data/variable section. Then add in a table (right mouse click in the left margin and click Insert Table) to that new section with one row and 3 columns and select the center cell and click Map Image from the main menu. Keep in mind that each section doesnt represent a page so depending on how much room you have in your page you will need to resize it and preview it to make sure you can see it and run it again. You may need to insert a page break after the map section so you dont have a blank page after the map and you do that by right mouse clicking the left margin again and selecting Section Properties and choose insert page break after section.Regards,Jeff
