import arcpy feature_class = "c:/Data/wells.shp" layer = "temp_layer" arcpy.MakeFeatureLayer_management(feature_class, layer) # Create a describe object desc = arcpy.Describe(layer) # Create a fieldinfo object field_info = desc.fieldInfo # Get index of desired field for which to set ratio policy # Let's say your desired field is called 'area' fldIndex = field_info.findFieldByName("area") # Set the policy field_info.setSplitRule(fldIndex, "RATIO")
inFeaturesAlb = "blocks_01_alb.shp" layer = "temp_layer" arcpy.MakeFeatureLayer_management(inFeaturesAlb, layer) # Create a describe object desc = arcpy.Describe(layer) # Create a fieldinfo object field_info = desc.fieldInfo # Get index of desired field for which to set ratio policy # Let's say your desired field is called 'area' fldIndex = field_info.findFieldByName("POP10") # Set the policy field_info.setSplitRule(fldIndex, "RATIO") ###################################################################### #Do the intersection ##################################################################### intOut = "State_01_int_3.shp" inFeatures_int = [USA_layer, layer] arcpy.Intersect_analysis(inFeatures_int, intOut)
Hi Wayne -- Sorry to keep this going but I've had trouble making this work in a stand-alone setting. I used the code above, which seemed to work fine. However, when I proceeded the intersect the ratio split policy wasn't honored. I'm wondering if I'm missing a step to connect the policy more explicitly back to the layer that is input to the intersect. Code below. Thanks for any thoughts, Mike inFeaturesAlb = "blocks_01_alb.shp" layer = "temp_layer" arcpy.MakeFeatureLayer_management(inFeaturesAlb, layer) # Create a describe object desc = arcpy.Describe(layer) # Create a fieldinfo object field_info = desc.fieldInfo # Get index of desired field for which to set ratio policy # Let's say your desired field is called 'area' fldIndex = field_info.findFieldByName("POP10") # Set the policy field_info.setSplitRule(fldIndex, "RATIO") ###################################################################### #Do the intersection ##################################################################### intOut = "State_01_int_3.shp" inFeatures_int = [USA_layer, layer] arcpy.Intersect_analysis(inFeatures_int, intOut)
import arcpy # Local variables: blocks_01_alb_shp = "...\\blocks_01_alb.shp" USA_int_131111 = "USA_int_131111" State_01_int_7_shp = "...\\State_01_int_7.shp" blocks_01_alb_Layer1 = "blocks_01_alb_Layer1" # Process: Make Feature Layer arcpy.MakeFeatureLayer_management(blocks_01_alb_shp, blocks_01_alb_Layer1, "", "", "FID FID VISIBLE NONE;Shape Shape VISIBLE NONE;STATEFP10 STATEFP10 VISIBLE NONE;POP10 POP10 VISIBLE RATIO") # Process: Intersect arcpy.Intersect_analysis("blocks_01_alb_Layer1 #;USA_int_131111 #", State_01_int_7_shp, "ALL", "", "INPUT")
inFeaturesAlb = "blocks_01_alb.shp" # Create a describe object desc = arcpy.Describe(inFeaturesAlb) # Create a fieldinfo object field_info = desc.fieldInfo # Get the field index and set ratio policy field_info.setSplitRule(field_info.findFieldByName("POP10"), "RATIO") layer = "temp_layer" arcpy.MakeFeatureLayer_management(inFeaturesAlb, layer, '', '', field_info) ###################################################################### #Do the intersection ##################################################################### intOut = "State_01_int_3.shp" inFeatures_int = [USA_layer, layer] arcpy.Intersect_analysis(inFeatures_int, intOut)
