I get this error and am not sure why...
I am able to sign in to my portal, download surveys. When I try to submit I get this error.
Any advice?
JTedrick-esristaff
Hi Tucker,
To fix this issue, please modify below code in Survey123 App XForms/XFormFeatureService.qml file
var formData = { "edits": encodeURIComponent(JSON.stringify(edits)), "rollbackOnFailure": true, "useGlobalIds": useGlobalIds }<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
to
var formData = { "edits": JSON.stringify(edits), "rollbackOnFailure": true, "useGlobalIds": useGlobalIds }<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks
Shobana
After further investigation I have determined that Cloud Make using the AppStudio 1.3.46 is breaking my apps.
Any app that was Built with the 1.3.46 version a week or so ago works fine, any app recently Made with AppStudio 1.3.46 will break the EXACT same app.
I would guess that since the AppStudio upgrade for the new version is has broken the AppStudio 1.3.46 Make.
I would guess that I need to upgrade to the new version of AppStudio, it would appear that AppStudio 1.3.46 is NOT COMPATIBLE with the new Cloud Make!
Yes, there is a change between 1.3 and 1.4 in how URL encoding is handled (we previously had a workaround implemented in Survey123) - SSuresh-esristaff or elvin, could you provide guidance on if it's easy to adjust the workaround?
I just upgraded to 1.4.18 and received the same results.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
