I am trying to create a new inline gallery items...Could anyone help me with an example to create a Custom Inline Gallery with Custom Gallery Items.#arcgisprosdk
Hi Janaki,
Here is a sample of an Inline Gallery in the arcgi-spro-community-samples repo. You can also find some documentation on gallery items in the wiki page.
Thanks
Uma
Hi Uma,
I have checked and executed the Data Reviewer Application with the Inline Gallery in it...But the items didnt get loaded in the Inline Gallery on building the solution from the given Examples....May it would load the items once we run the batch reviewer....
But My issue is I would like to create the items in the Inline Gallery with categories as similar to this.
Hi Janaki
You can accomplish this by setting the Group property of GalleryItem. In the config.daml where you define the gallery element, set the "showGroup" attribute to "true". Like this:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>galleries</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>gallery</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>GalleryDemo_WebMapsGallery<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">showGroup</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>true<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">caption</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Web Maps Gallery<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">className</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>WebMapsGallery<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">itemsInRow</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>5<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">dataTemplateFile</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>pack://application:,,,/GalleryDemo;component//WebMapsGalleryTemplate.xaml<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">templateID</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>WebMapsGalleryItemTemplate<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">resizable</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>true<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">largeImage</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Images\GenericButtonOrange32.png<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">keytip</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>z3<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>tooltip</SPAN> <SPAN class="attr-name token">heading</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Web Maps<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Tooltip text<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>disabledText</SPAN> <SPAN class="punctuation token">/></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>tooltip</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>gallery</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>galleries</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Attached is an updated Web maps Gallery sample with the "categories".
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
