Is it possible to have more than one layerlist in one web app. I would like to add another layerlist where i can have only some of the layers visible in layerList1 and other layers visible in layerList2
Richard,
Through direct dom manipulation you can:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>LayerList widget <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.12</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.12/esri/themes/light/main.css"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.12/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/views/SceneView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/WebScene"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/core/watchUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-style"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>SceneView<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">,</SPAN> WebScene<SPAN class="punctuation token">,</SPAN> query<SPAN class="punctuation token">,</SPAN> watchUtils<SPAN class="punctuation token">,</SPAN> domStyle<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> scene <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebScene</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PortalItem()</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"adfad6ee6c6043238ea64e121bb6429a"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SceneView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> scene <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"layerlist1"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Add widget to the top right corner of the view</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//workaround for making sure layerlist is ready</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> lis <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'li[aria-labelledby $= "__title"]'</SPAN><SPAN class="punctuation token">,</SPAN> layerList<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> lis<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"San Francisco"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Growth Potential"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layerList2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Add widget to the top right corner of the view</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList2<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//workaround for making sure layerlist is ready</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>layerList2<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> lis <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'li[aria-labelledby $= "__title"]'</SPAN><SPAN class="punctuation token">,</SPAN> layerList2<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> lis<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Transit lines in service"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Transit lines planned"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"calcite"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Robert Scheitlin, GISP, What would be the way if the layerlist were inside an expand widget?
No difference. Same code would apply.
I tried adding an expand widget, but I don't get it to work, what am I doing wrong?
<SPAN class="doctype token"><!DOCTYPE html></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">charset</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>initial-scale<SPAN class="punctuation token">=</SPAN>1, maximum-scale<SPAN class="punctuation token">=</SPAN>1,user-scalable<SPAN class="punctuation token">=</SPAN>no<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>LayerList widget - 4.12<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.12/esri/themes/light/main.css<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="selector token">html, body, #viewDiv</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">overflow</SPAN><SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.11/<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/views/SceneView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/WebScene"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Expand"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/core/watchUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-style"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>SceneView<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">,</SPAN> WebScene<SPAN class="punctuation token">,</SPAN> Expand<SPAN class="punctuation token">,</SPAN> query<SPAN class="punctuation token">,</SPAN> watchUtils<SPAN class="punctuation token">,</SPAN> domStyle<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> scene <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebScene</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PortalItem()</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"adfad6ee6c6043238ea64e121bb6429a"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SceneView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> scene <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"layerlist1"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layerListExpand <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> expandIconClass<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esri-icon-layers"</SPAN><SPAN class="punctuation token">,</SPAN> expandTooltip<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Operational Layers"</SPAN><SPAN class="punctuation token">,</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> expanded<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> layerList <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerListExpand<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/* var layerList = new LayerList({ view: view, id: "layerlist1" }); // Add widget to the top right corner of the view view.ui.add(layerList, "top-right"); */</SPAN> <SPAN class="comment token">//workaround for making sure layerlist is ready</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> lis <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'li[aria-labelledby $= "__title"]'</SPAN><SPAN class="punctuation token">,</SPAN> layerList<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> lis<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"San Francisco"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Growth Potential"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layerList2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Add widget to the top right corner of the view</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList2<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//workaround for making sure layerlist is ready</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>layerList2<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> lis <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'li[aria-labelledby $= "__title"]'</SPAN><SPAN class="punctuation token">,</SPAN> layerList2<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> lis<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Transit lines in service"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Transit lines planned"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>li<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>calcite<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewDiv<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Johan,
OK, I see the issue is the dom node the query needs to work with is now the expand widgets dom node:
<SPAN class="keyword token">var</SPAN> lis <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'li[aria-labelledby $= "__title"]'</SPAN><SPAN class="punctuation token">,</SPAN> layerListExpand<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Instead of the layerList.domNode
Thanks Robert.
However, It doesn't work if I add the layerList to a container
var otherLayer = new LayerList({ view: view , container: "oRisk" });
I gather I would have to edit the following?
var lis = query('li[aria-labelledby $= "__title"]', otherRisksLayer.domNode);
not quite sure to what though. Any advise?
You have to query the list container node.
<SPAN class="keyword token">var</SPAN> lis <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'li[aria-labelledby $= "__title"]'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"oRisk"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
That doesn't seems to work:
//configure customer layer list for other risks var otherLayer = new LayerList({ view: view, container: "oRisk", listItemCreatedFunction: function (event) { item = event.item; item.panel = { content: "legend" }; }}); view.ui.add(otherLayer, "manual"); //workaround for making sure layerlist is ready watchUtils.when(otherLayer, 'operationalItems.length', function(){console.log("in function"); var lis = query('li[aria-labelledby $= "__title"]', "oRisk");
console.log("LIS ", lis);
lis.map(function(li) {console.log("in li ", li);
Results:
Only 2 of 3 logs show
I am trying with the expand but not getting the desired result :
var layerList2 = new LayerList({ view: view, container: document.createElement("div"), listItemCreatedFunction: function (event) { item = event.item; item.panel = { content: "legend" }; } });var expandLyr = new Expand({ view: view, content: layerList2.domNode, expandTooltip: "Layers With Legend", collaseTooltip: "Layers With Legend", expandIconClass: "esri-icon-layers" });view.ui.add(expandLyr, "bottom-right");
watchUtils.when(layerList2, 'operationalItems.length', function () {setTimeout(function () {var lis = query('li[aria-labelledby $= "__title"]', expandLyr.domNode);
lis.map(function (li) { console.log(li.innerText);});}, 0)});
Results :
Notice that only subs have a innerText. How do I get around this as I need to remove these from the layerList
I do not have this issue with the layerList by itself; only with Expand
Issue resolved by putting the code outside view.when()
I am trying to modify the multiple layerList code for use with the latest ArcGIS JavaScript api 4.15 and am not having much luck. I tried removing dojo query and domStyle and substituting vanilla javascript but got lost trying to capture the list and manipulate it.
Has anyone successfully upgrade this code or can anyone help me with this?
Thanks.
