Type t = Type.GetTypeFromProgID("esriDataSourcesGDB.AccessWorkspaceFactory.1");//("{DD48C96A-D92A-11D1-AA81-00C04FA33A15}"); System.Object obj = Activator.CreateInstance(t);
I am developing ArcMap extensions quite frequently, but it was never a problem to create an instance in C# with the new keyword. May be you are developing an ArcGIS engine application? In this case, I would try to check out a license before instantiating the geoprocessor object.http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//00010000043p000000The Geoprocessor is not listed, so using the Activator class is not the right way.Best regards, Stefan
ESRI.ArcGIS.ConversionTools.FeatureClassToFeatureClass fcToFcTool = new ESRI.ArcGIS.ConversionTools.FeatureClassToFeatureClass(); fcToFcTool.in_features = featureLayer; fcToFcTool.out_path = outputDirectory; fcToFcTool.out_name = newTableName; if (!string.IsNullOrEmpty(query)) fcToFcTool.where_clause = query; Geoprocessor gp = new ESRI.ArcGIS.Geoprocessor.Geoprocessor(); gp.Execute(fcToFcTool, null);
Below is the code from a Windows service that I wrote a while back. I fully qualified the class names to avoid confusion with the old Geoprocessor class in the Geoprocessing library. ESRI.ArcGIS.ConversionTools.FeatureClassToFeatureClass fcToFcTool = new ESRI.ArcGIS.ConversionTools.FeatureClassToFeatureClass(); fcToFcTool.in_features = featureLayer; fcToFcTool.out_path = outputDirectory; fcToFcTool.out_name = newTableName; if (!string.IsNullOrEmpty(query)) fcToFcTool.where_clause = query; Geoprocessor gp = new ESRI.ArcGIS.Geoprocessor.Geoprocessor(); gp.Execute(fcToFcTool, null);
Creating an instance of the COM component with CLSID {5374EC4C-1AA2-4829-A811-DE624ECEC23F} from the IClassFactory failed due to the following error: 80010105
Sounds like this might be an install issue ... if you search your registry, do you find this key?If not, consider re-installing.
public static void TestGp() { Guid g = new Guid("5374EC4C-1AA2-4829-A811-DE624ECEC23F"); Type t = Type.GetTypeFromCLSID(g); Debug.Print(t.ToString()); GeoProcessor gp = Activator.CreateInstance(t) as GeoProcessor; Debug.Print(gp.OverwriteOutput.ToString()); }
Here's the key I have (on Vista64):HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{5374EC4C-1AA2-4829-A811-DE624ECEC23F}Do you have this key (or its 32 bit equivalent) ?Does this code work for you?public static void TestGp() { Guid g = new Guid("5374EC4C-1AA2-4829-A811-DE624ECEC23F"); Type t = Type.GetTypeFromCLSID(g); Debug.Print(t.ToString()); GeoProcessor gp = Activator.CreateInstance(t) as GeoProcessor; Debug.Print(gp.OverwriteOutput.ToString()); }
What is the GUI for the Geoprocessor object not GeoProcessor?
Please elaborate.
Hi Kirk-2 questions: What is the GUI for the Geoprocessor object not GeoProcessor? I was using Geoprocessor object because its execute method only takes 2 arguments.If I have to use GeoProcessor then the first parameter required is string Name. What is Name? The Name of the tool? FeatureClassToFeatureClass_Conversion?
Are you creating it repeatedly in a loop?Did you try calling Marshal.ReleaseCOMobject on it once you're finished with it?
I'm having the exact same issue with my windows console EXE in C# for 10.2.1.3497 - even the part where it works sometimes but not every time! Some times it works just fine. Others it fails with that same error:
Creating an instance of the COM component with CLSID {5374EC4C-1AA2-4829-A811-DE624ECEC23F} from the IClassFactory failed due to the following error: 80010105.System.Runtime.InteropServices.COMException (0x80010105): Creating an instance of the COM component with CLSID {5374EC4C-1AA2-4829-A811-DE624ECEC23F} from the IClassFactory failed due to the following error: 80010105.
at ESRI.ArcGIS.Geoprocessor.Geoprocessor..ctor()
I'm checking out an Advanced license at the beginning so that part is working fine.
I'm referencing the following .net assemblies:
ESRI.ArcGIS.Geoprocessing
C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\DotNet\ESRI.ArcGIS.Geoprocessing.dll
runtime v2.0.50727
version 10.2.0.0
C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\DotNet\ESRI.ArcGIS.Geoprocessor.dll
Here's my code (it fails right on that first line when executing that Geoprocessor() constructor):
Geoprocessor GP <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Geoprocessor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> IGeoProcessorResult processorResult <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> createFileGDBTool <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">CreateFileGDB</SPAN><SPAN class="punctuation token">(</SPAN>exportFolder<SPAN class="punctuation token">,</SPAN> fileGdbName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> processorResult <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IGeoProcessorResult<SPAN class="punctuation token">)</SPAN>GP<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Execute</SPAN><SPAN class="punctuation token">(</SPAN>createFileGDBTool<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> gpTool <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureClassToFeatureClass</SPAN><SPAN class="punctuation token">(</SPAN>inputtable<SPAN class="punctuation token">,</SPAN> fullExportPath<SPAN class="punctuation token">,</SPAN> fileGdbTableName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> processorResult <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IGeoProcessorResult<SPAN class="punctuation token">)</SPAN>GP<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Execute</SPAN><SPAN class="punctuation token">(</SPAN>gpTool<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Why in the world would it work sometimes and not every time?
