Is there a way to see if a feature class exists in a file geodatabase OR loop through and get a list of all the feature class in a file geodatabase using the Pro SDK?
Matthew,
I assume you are asking about feature classes inside a file geodatabase (a feature layer is a map layer that obtains its data from a feature class). The best way to check for feature class existence is the following:
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">bool</SPAN> <SPAN class="token function">FeatureClassExists</SPAN><SPAN class="punctuation token">(</SPAN>Geodatabase geodatabase<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> featureClassName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> FeatureClassDefinition featureClassDefinition <SPAN class="operator token">=</SPAN> geodatabase<SPAN class="punctuation token">.</SPAN>GetDefinition<SPAN class="operator token"><</SPAN><SPAN class="token function">FeatureClassDefinition</SPAN><SPAN class="punctuation token">(</SPAN>featureClassName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> featureClassDefinition<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Dispose</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// GetDefinition throws an exception if the definition doesn't exist</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
To get a list of all of the feature classes in a geodatabase, use Geodatabase.GetDefinitions<FeatureClass>() and iterate through the returned list.
I hope this helps,
--Rich
Thanks Rich!
I did mean feature class, I corrected the question. When I tried your suggestion I get the error "Non-invocable member ;FeatureClassDefinition' cannot be used like a method. Below is what I ended up trying, it runs without error, but it still does not see the feature class when it does exist.
<SPAN class="keyword token">string</SPAN> projGDBPath <SPAN class="operator token">=</SPAN> Project<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN>DefaultGeodatabasePath<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">string</SPAN> FC <SPAN class="operator token">=</SPAN> TXB<SPAN class="punctuation token">.</SPAN>Text<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// From a text box in the xaml</SPAN> <SPAN class="keyword token">string</SPAN> fcFINAL <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>projGDBPath<SPAN class="punctuation token">,</SPAN> FC<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">await</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Tasks<SPAN class="punctuation token">.</SPAN>QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN>Geodatabase geodatabase <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Geodatabase</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FileGeodatabaseConnectionPath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>projGDBPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> FeatureClassDefinition featureClassDefinition <SPAN class="operator token">=</SPAN> geodatabase<SPAN class="punctuation token">.</SPAN>GetDefinition<SPAN class="operator token"><</SPAN>FeatureClassDefinition<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN>fcFINAL<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> featureClassDefinition<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Dispose</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Dialogs<SPAN class="punctuation token">.</SPAN>MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"It exists"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">{</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Dialogs<SPAN class="punctuation token">.</SPAN>MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"It Does Not Exist"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Ah, looks like I forgot the closing > in my code snippet.
I would suggest you get all of the feature class definitions inside the file geodatabase and make sure the list matches your expectations. To do this call FeatureClass.GetDefinitions<FeatureClassDefinition>() and iterate through the returned list.
This does not seem to successfully get a list of the feature class either, it returns the definitions but not the actual name. I cannot find any examples of doing this in the snippets or help either. Probably going to switch to python to do this task, but I would like to avoid that because python takes a lot longer to run.
I'm not sure I understand. Once you get the FeatureClassDefinition object, what is returned when you call FeatureClassDefinition.GetName()?
Are you sure you're looking at the right file geodatabase? By default, the project workspace (Project.Current.DefaultGeodatabasePath), which is the file geodatabase that is automatically created when you create a project, *is* empty.
By the way, going back to your original code snippet, you should call GetDefinition() with FC, not fcFinal.
