Hello,
I can not figure out how to zoom the map frame in layout view to a specific layer using ArcGIS Pro SDK (C#)?
Thank you!
Hi Joshua
Here is a code snippet you can use to zoom the map frame in layout view to a specific layer:
LayoutProjectItem layoutItem <SPAN class="operator token">=</SPAN> Project<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN>GetItems<SPAN class="operator token"><</SPAN>LayoutProjectItem<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN>item <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> item<SPAN class="punctuation token">.</SPAN>Name<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Equals</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"MyLayout"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//Get the layout from the layout project item</SPAN> Layout layout <SPAN class="operator token">=</SPAN> layoutItem<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetLayout</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Get the map frame in the layout</SPAN> MapFrame mapFrame <SPAN class="operator token">=</SPAN> layout<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"New Map Frame"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> MapFrame<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Get map </SPAN> <SPAN class="keyword token">var</SPAN> mapFrameMap <SPAN class="operator token">=</SPAN> mapFrame<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Get the specific layer you want from the map</SPAN> <SPAN class="keyword token">var</SPAN> lyrOfInterest <SPAN class="operator token">=</SPAN> mapFrameMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetLayersAsFlattenedList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>OfType<SPAN class="operator token"><</SPAN>FeatureLayer<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Get the Layer's extent</SPAN> <SPAN class="keyword token">var</SPAN> lyrExtent <SPAN class="operator token">=</SPAN> lyrOfInterest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">QueryExtent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Zoom to this extent in the MapFrame</SPAN> <SPAN class="comment token">//Note: This method will be deprecated at 2.3. </SPAN> <SPAN class="comment token">//But you can use mapFrame.SetCamera(lyrOfInterest) instead. (This will be a new overload available in 2.3)</SPAN> mapFrame<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ZoomTo</SPAN><SPAN class="punctuation token">(</SPAN>lyrExtent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks
Uma
Thank you this worked great! But is there a way to 1) zoom to only a selected feature in a layer rather than the whole layer, and then 2) zoom out a certain percentage more? For example, zoom to California in the states layer. And then zoom out a bit more so that it is not zoomed all the way in to California?
Thank you
Hi Joshua,
The way I got this to work was to create a query and iterate using a cursor. You want to make sure your query returns one feature.
////Zoom to the envelope of each feature //Reference the layout Layout layout = LayoutView.Active.Layout;
//Select the feature await QueuedTask.Run(() => { //Reference the mapframe, associated map, and build a query MapFrame mf = layout.FindElement("Map Frame") as MapFrame; Map m = mf.Map; FeatureLayer fl = m.FindLayers("GreatLakes").First() as FeatureLayer; QueryFilter qf = new QueryFilter(); string whereClause = "NAME = 'Lake Erie'"; qf.WhereClause = whereClause;
//Zoom to the feature using (ArcGIS.Core.Data.RowCursor rowCursor = fl.Search(qf)) { while (rowCursor.MoveNext()) { // get the shape from the row ArcGIS.Core.Data.Feature feature = rowCursor.Current as ArcGIS.Core.Data.Feature; Polygon polygon = feature.GetShape() as Polygon; Envelope env = polygon.Extent as Envelope; mf.ZoomTo(env); } } });
I hope this helps,
Jeff
Thank you! I am trying to zoom out a certain percentage further, so for example, zoom to Lake Erie, but then zoom out 10% further. Is that possible? Also, I am trying to do a select by location (select state that intersects with a polygon project boundary, and then zoom to that state (but out a bit further such as 10%).
Try adding the last 3 lines to the code I already provided. I simply multiply the scale by 110%
// get the shape from the row ArcGIS.Core.Data.Feature feature = rowCursor.Current as ArcGIS.Core.Data.Feature; Polygon polygon = feature.GetShape() as Polygon; Envelope env = polygon.Extent as Envelope; mf.ZoomTo(env);Camera cam = mf.Camera; cam.Scale = cam.Scale * 1.1; mf.SetCamera(cam);
Also, concerning your select by location question ... see: https://community.esri.com/thread/210362-how-can-i-make-a-select-by-location-in-pro-sdk
Just FYI. I was able to modify a little to make it work for my case where I need to zoom to a feature from certain feature layer in Map view. Hope it helps anyone.
await QueuedTask.Run(() =>{//Reference the mapframe, associated map, and build a queryFeatureLayer fl = MapView.Active.Map.FindLayers("FeatureLayerName").First() as FeatureLayer;QueryFilter qf = new QueryFilter();string whereClause = "MyField = 'FieldValue'";qf.WhereClause = whereClause;
//Zoom to the featureusing (ArcGIS.Core.Data.RowCursor rowCursor = fl.Search(qf)){while (rowCursor.MoveNext()){// get the shape from the rowArcGIS.Core.Data.Feature feature = rowCursor.Current as ArcGIS.Core.Data.Feature;Polygon polygon = feature.GetShape() as Polygon;Envelope env = polygon.Extent as Envelope;//mf.ZoomTo(env);MapView.Active.ZoomTo(env);
