<value prompt="Select from the following" uniquevalsfromfield="VALVEID" isvaluerequired="true" autosubmit="true">VALVEID = '[value]'</value>
<layer> <token /> <definitionexpression /> <enableexport>true</enableexport> <name>Address</name> <url>http://GIS01.lebanon.local/arcgis/rest/services/OperationalLayers/Planning/MapServer/2</url> <expressions> <expression alias="Address" textsearchlabel="Search Complete Address:" isvaluerequired="true"> <values> <value prompt="Example: 925 Main St" isvaluerequired="true"> upper ( SITUS ) LIKE upper ( value ]%')</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Zoning</graphicalsearchlabel> <spatialsearchlayer>false</spatialsearchlayer> <titlefield>ADDRESS</titlefield> <fields all="true" /> <links /> <zoomscale usegeometry="true" zoompercent="2" /> <autoopendatagrid>false</autoopendatagrid> <queryattachments>false</queryattachments> <relates /> <symbology> <simplemarkersymbol color="0xff0000" alpha="0.5"> </simplemarkersymbol> </symbology> </layer>
<relates> <relate id="0" label="Contract Attachments" enableexport="true" enableprint= "true" icon="assets/images/i_folder.png"> <fields all="false" > <field name="ContractNumber"/> <field name="ContractName"/> <field name="SMuniOrSAgency"/> <field name="WebRelativeImagePath" alias="Image" hyperlinkgridfield="true" hyperlinkaliastext="Show Attachment"/> </fields> </relate> </relates>
Do you see the the relates listed at the bottom of the rest service page like this?Relationships:calhoun.COUNTY.A_Bridge (0) -- Related To: ABIMS Bridges (0) calhoun.COUNTY.ADT (1) -- Related To: Average Daily Traffic (1) calhoun.COUNTY.Rail_Cross (2) -- Related To: Railroad Crossings (2) calhoun.COUNTY.Signs (3) -- Related To: Road Signs (3) calhoun.COUNTY.Guardrail (4) -- Related To: Guardrails (4)
OK, but the fact that it works in ArcMap is only half the battle. Now you need to test a Query of the related data using the REST End point. Can you post the test of your relates from the rest service page like I did?
