Well, not sure if you can do anything about it with the compiled version.However, if you have the capability to compile, see this thread: http://forums.arcgis.com/threads/65432-(e)mapswitcher-widget-basemapsContainer-on-top?p=227012#post227012R_
Clint, For you to search multiple you would have to build a widget using the findtask of the the Flex API. The problem with the find task is that you can not search spatially.
Hey,I just used popups to see if my service is working right with popups.I guess You have to configure popups separately from regular popups in eSearch Widget?Thank you
<floatorfixed>float</floatorfixed><!-- possible values are fixed and float -->
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
