I am getting this error when i am trying to reconcile.This error is saying of some column conflict.Please suggest anything?Arcgis 10.4 oracle 11g
I have checked the locked mode and type also.
Does that feature class with the issue have a join on it in the child version?
Have you run a compress first then reconciled/posted?
FC is not joined and i am trying to reconcile first .
Should i have to run compress first?
I am still facing the same error can some body guide me to fix it?I have checked compare schema tools and found no changes.if i just take back up of both default and child versioned and after that load all the data in the default version? Please suggest me any solution.
I would recommend opening an Esri Technical Support case to have them investigate in more detail.
