import arcpyimport arcgisfrom arcgis.gis import GIS
map = gis.map("Chennai")map
I installed the nodejs using conda after that I am trying to run the following commands
jupyter labextension installjupyter-widgets/jupyterlab-manager
jupyter labextension install arcgis-map-ipywidget@1.5.2
but nothing is happening and I am getting the above output and the same error.
Vaibhav,
I think the Node.js is not installed correctly- I had some similar problems when I got started with JupyterLab.
Try this:
From the new environments command line:
Start JupyterLab and it should work…
