I am trying to use the Python Mid() function to return strings starting at the 5th character.
I have tried
!STR_NAME!.Mid(5:20)
but that gives me a traceback error
Can someone point me in the right direction?
Thanks
Never heard of the mid() functin and couldn't find it with dr. google.
myString <SPAN class="operator token">=</SPAN> <SPAN class="string token">'abcdefghijklmnopqrstuvwxyz'</SPAN> x <SPAN class="operator token">=</SPAN> myString<SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">20</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#returns 'fghijklmnopqrst'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This works for me...
how do I use that expression on a Field in ArcGIS Pro so it returns values starting at the 5th character?
Slice lesson
<SPAN class="comment token"># ---- python slicing... </SPAN> b <SPAN class="operator token">=</SPAN> <SPAN class="string token">"abcdefghijklmnopqrstuvwxyz"</SPAN> str<SPAN class="punctuation token">(</SPAN>b<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">20</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="string token">'fghijklmnopqrst'</SPAN> str<SPAN class="punctuation token">(</SPAN>b<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="string token">'fghijklmnopqrstuvwxyz'</SPAN> str<SPAN class="punctuation token">(</SPAN>b<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="string token">'vwxyz'</SPAN> str<SPAN class="punctuation token">(</SPAN>b<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="string token">'abcde'</SPAN> <SPAN class="comment token"># ---- why use str????</SPAN> str<SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="string token">'No'</SPAN> None<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> File <SPAN class="string token">"<ipython-input-18-5a2d59b27828>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN> None<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> TypeError<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'NoneType'</SPAN> object <SPAN class="keyword token">is</SPAN> <SPAN class="operator token">not</SPAN> subscriptable<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
See Dan's suggestions below... or:
str<SPAN class="punctuation token">(</SPAN>!FieldName!<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">20</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
resources for you: Cutting and slicing strings in Python - Python Central , Python str() - Python Standard Library
as per the lesson... 'b' is anything
like str(!STR_NAME!)[5:20]
Thanks guys! I got it to execute but it erased more chars than I wanted. Now I just have to re run the models and change the parameters around when I get to this point.
Sometimes you just need to fiddle with the indexes to get it just right...
That program is buggy as hell. I started my whole model again from the beginning and it stopped when it got to this part with the same error
but yet it worked when I tried it while we were discussing in this thread.
Thanks for helping me guys!
