y = 0 TestString = str (y + 1) + ': ' + str(SelectedWRs) + '= ' + str (Values) + ' cfs' x = 1 counter = count.getOutput(0) counter2 = int (counter) while x < counter2: y += 1 TestString = TestString + '\n' + str (y + 1) + ': ' + str(SelectedWRs) + '= ' + str (Values) + ' cfs' x = x + 1 ProtectedWaterBoolean = pythonaddins.MessageBox('Selected Management Point: ' + str(selection) + '\n\n' + 'Water Rights with Protected Water on ' + str(SelectedDate) + ':' + '\n' + TestString + '\n\n' + 'Total CFS Protected: ' + str(ValuesSum) + '\n\n', 4)
from Tkinter import * from ttk import * import tkMessageBox class DisplayResults(): def __init__(self): self.root = Tk() self.root.title("Geoprocessing Results") self.root.minsize(width=770, height=300) self.root.config(padx=10, pady=10) Style().configure(".", font=("Helvetica", 10)) self.frame = Frame() self.frame.pack(fill="both", expand=1) self.createWidgets() self.root.protocol("WM_DELETE_WINDOW", self.quitCallback) def createWidgets(self): self.textbox = Text(self.frame, height=20, width=120, relief="sunken", state="normal") self.textbox.pack(fill="both", expand=1) self.yscrollbar = Scrollbar(self.textbox, orient="vertical", cursor="arrow" ,command=self.textbox.yview) self.yscrollbar.pack(side="right", fill="y") self.textbox["yscrollcommand"]=self.yscrollbar.set def printToScreen(self, content): self.textbox.insert("end", content + "\n") def quitCallback(self): """ If user closes the prompt window, the program will exit on 'OK' """ if tkMessageBox.askokcancel("Quit", "Do you really wish to quit?"): self.root.destroy() sys.exit(1) gui = DisplayResults() gui.printToScreen("data") gui.root.mainloop()
visibleFields = ["ID", "DesiredField1", "DesiredField2"] field_info = arcpy.Describe("FeatureLayer").fieldInfo for index in xrange(0, field_info.count): if field_info.getfieldname(index) not in visibleFields: field_info.setvisible(index,"HIDDEN") arcpy.MakeFeatureLayer_management("FeatureLayer","Feature_Layer_With_New_Visibilities","","",field_info) # Run your reporting process on your new feature layer # Clean up your feature layer with new visibilities when you're done with it. arcpy.Delete_management("Feature_Layer_With_New_Visibilities")
dateField = # Method to get the date field you want # Method that puts each row into a dictionary def rows_as_dicts(cursor): colnames = cursor.fields for row in cursor: yield dict(zip(colnames, row)) # Record of the data you want in your new table fields = ["id",dateField] data = [row for row in rows_as_dicts(arcpy.da.SearchCursor("Your Table",fields)) # Create your new table -- Mine is "in_memory" table = arcpy.CreateTable_management("in_memory", tableName) arcpy.AddField_management(table, "id", "LONG", 9) arcpy.AddField_management(table, dateField, "TEXT") # Populate your table with arcpy.da.InsertCursor(table, fields) as cursor: for row in data: cursor.insertRow([row["id"], row[dateField]]) # Run your reporting with your new in_memory table # Clean up your temporary table arcpy.Delete_management(table)
import arcpy import pythonaddins import pickle, os from subprocess import Popen, PIPE class YourPythonAddinClass(object): """ Implementation for Create_New_Point_addin.createNewXYPoint (Button) """ def __init__(self): ... ... ... def yourOnClickFunction(self): featureClass = arcpy.mapping.Layer("Your Feature Class") dateField = # Method to get the date field you want fields = ["id",dateField] data = [row for row in arcpy.da.SearchCursor(featureClass,fields)] data.insert(0, tuple(fields)) dataDumpFile = os.path.join(os.path.dirname(os.path.abspath(__file__)), "datadump.p") pickle.dump(data, open(dataDumpFile,"wb")) open_GUI("listViewGUI.py",dataDumpFile) def open_GUI(gui_file_name, file_location): file_path = os.path.join(os.path.dirname(os.path.abspath(__file__)), gui_file_name) proc = Popen([file_path,file_location], shell=True, stdout=PIPE, bufsize=1) stdoutdata, stderrdata = proc.communicate() return stdoutdata
import Tkinter as tk import tkFont, ttk, tkMessageBox import math, pickle, sys class ListBox(object): """use a ttk.TreeView as a multicolumn ListBox""" sampleHeader = ["Column 1","Column 2"] sampleData = [("data1","data1"),("data2","data2")] def __init__(self, header=sampleHeader, data=sampleData): self.root = tk.Tk() self.root.wm_title("Table Output") self.root.minsize(width=300, height=300) ttk.Style().configure('.', font=('Courier', 10)) self.header = header self.data = data self.tree = None self._setup_widgets() self._build_tree() self.root.protocol("WM_DELETE_WINDOW", self.quitCallback) self.root.mainloop() def _setup_widgets(self): container = ttk.Frame() container.pack(fill='both', expand=True) # create a treeview with dual scrollbars self.tree = ttk.Treeview(columns=self.header, show="headings") vsb = ttk.Scrollbar(orient="vertical", command=self.tree.yview) self.tree.configure(yscrollcommand=vsb.set) self.tree.grid(column=0, row=0, sticky='nsew', in_=container) vsb.grid(column=1, row=0, sticky='ns', in_=container) container.grid_columnconfigure(0, weight=1) container.grid_rowconfigure(0, weight=1) def _build_tree(self): for col in self.header: self.tree.heading(col, text=col.title()) # adjust the column's width to the header string self.tree.column(col, width=tkFont.Font().measure(col.title())) for item in self.data: self.tree.insert('', 'end', values=item) # adjust column's width if necessary to fit each value for ix, val in enumerate(item): col_w = tkFont.Font().measure(val) if self.tree.column(self.header[ix], width=None) < col_w: self.tree.column(self.header[ix], width=int(math.floor(col_w * 1.75))) def quitCallback(self): """ If user closes the prompt window, the program will exit on 'OK' """ if tkMessageBox.askokcancel("Quit", "Do you really wish to quit?"): self.root.destroy() sys.exit(1) def main(argv): data = pickle.load(open(argv[1], "rb")) header = data[0] data_list = data[1:] guiTable = ListBox(header=header, data=data_list) main(sys.argv)
