I would like to edit multiple graphics at the same time with the Edit widget. I can manage to select the graphics I want to edit, but how could I edit them at the same time? Is it even possible?
Do you have a use case for this to better explain it? Are you talking about re-sizing a graphic to the same scale?
Thanks for the response, Tyrone!
I have graphics that consist of a polygon and a polyline on top of it. What I would want to do is rotate and move the graphics together at the same time. Would it be achievable?
You're a step ahead of me b/c you said you were able to select them both? If you're able to put them both in edit mode, I suppose you could have a go at trying to attaching the mouse event to both graphics. I don't see that working out too well though (but, it could be worth a try).
I should say that I do not have any idea if there is some functionality from the API that can accomplish this.
What I would do is just select one graphic, and edit one graphic. As you rotate that graphic, programmatically rotate the other graphic. Does that make sense? I want to say that there is some kind of on rotating type event you could piggy back on to change the graphic not in edit mode.
Thanks Tyrone,
The approach you proposed of programmatically changing the other graphic when one graphic is edited is probably the way to go, because I can't put both these graphics into edit mode. When the second graphic's edit session activates, it also deactivates the first graphic's edit session.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
