Hi ,
I just started using ARCGIS 10.2.2 and I need a Hec-geo ras extension for that. Would you please help me.
Sara
Sara Rastgou
The MFT site has current build -- HECGeoRAS 10.2.0.10 beta. Instructions for access are in this post -- https://community.esri.com/message/402547#402547 and then navigate to /camp/HECGeoRAS/Setup10.2_Beta directory.
An alternative http based download is here downloads /archydro/HecGeoRAS/10.2/
but this site is not kept as current (at present the HECGeoRAS builds posted are the same).
Stuart
Many thanks for your quick response. I was so impressed.
Appreciate your help.
Sara.
Hi.
Thanks for posting the download link. I have downloaded and installed the HEC GeoRAS.
I was able to convert the sdf to xml and do the layer set up. The import RAS data keep giving error as shown below. Please what am I doing wrong?
I had almost the same error (I downloaded the software from http://www.hec.usace.army.mil/software/hec-georas/downloads.aspx, not beta anymore).
Starting format transformation
Transforming to internal format
Validation internal format
Transforming to GDB format
Creating Geodatabase
Unable to cast object of type 'System.__ComObject' to type 'ESRI.ArcGIS.DataSourcesGDB.FileGDBWorkspaceFactoryClass'.
at ESRI.APWR.GISXDE.ArcGISCommun.Workspaces.WSFactory.Create(WSConnectionParams conParams)
at ESRI.APWR.GISXDE.Importer.GDEImporter.Import(XmlReader source, GDEImportFormat format, WSConnectionParams connParams) Failed to import RAS data!
Mikko
@Mikko,
Not sure it is root of your issue, but it is still a better bet to use the Esri Water Resources Group MFT (sftp) community repository for the current installers rather than the HEC downloads which tend to be un-patched.
The USACE HEC -- project site is currently posting an older HEC GeoRAS build, 10.2.0.2 with ApFramework 10.2.0.7, built 2013-12-20
The Esri MFT site currently posts HEC GeoRAS build 10.2.0.10 with ApFramework 10.2.0.16, built 2014-06-05
Review the readme.doc file posted to the MFT is usually will describe issues addressed with patches and dates released--although it looks a little out of date at the moment ( Christine Dartiguenave ?). Anyhow, you'll need to pay attention to the ApFramework if you have other Water Resource Group projects like ArcHydro installed.
Hi Stuart
Currently I am using ArcGIS 10.1 and HecGeoRAS 10.1 and want to upgrade to ArcGIS 10.2.2 . Just wondering if HEC GEORAS 10.2.0.10 works with ArcGIS 10.2.2.
Bishwa
Bshihwa,
I had no issues moving systems to Desktop 10.2.2 and current HEC GeoRAS builds,
But, you would have fewer issues if you completely remove HEC GeoRAS, along with any other extensions to ArcGIS for Desktop, followed by a full uninstall of ArcGIS for Desktop, and finally clear your per-user profile and the Windows registry. E.g. get to a point where there is no Esri product on your system. And only then start with a clean ArcGIS for Desktop installation.
Thanks a lot for your prompt response and advice. If I understood correctly, I need to uninstall previous Hec Georas, archydro, hec hms etc first and then after uninstalling arcgis 10.1 I should install fresh arcgis 10.2.2. After that Hec Georas 10.2.0.10 to get rid of issues.
Regards
Bishwa,
Your HEC RAS, or HEC HMS if installed, can remain. But the HEC GeoRAS preprocessor (and other Esri ApFramework based utilities, like ArcHydro Tools) will need to be uninstalled prior to the ArcGIS for Desktop install. It will then be replaced with a current build.
Doing it this way (removal of everything ArcGIS related) prevents issues during installation and setup.
I was wondering if you had tried this for 10.3 version. I am trying to get started working with HEC, but am not able to download the software with the new version of Arc.
Any suggestions are appreciated!
Best,Jessie
I was wondering if you had any advice for using HEC with 10.3? I am just getting familiar with the software and wanted to incorporate it into my analysis but don't think the installer recognizes my version of 10.3.
Any advice is appreciated!
