geometryService.project(multipoint.points, map.spatialReference, function (results)
geometryService.project(multipoint, map.spatialReference, function (results)
multipoint.points are not the type of Point geometry, but an array of coordinates in number type. Multipoint is a valid geometry type that can be fed into geometryService.project directly.Try to change:geometryService.project(multipoint.points, map.spatialReference, function (results)To:geometryService.project(multipoint, map.spatialReference, function (results)
var multipoint = new Multipoint(map.spatialReference); for (i = 0; i < arrycoord.length; i = i + 2) { var x = arrycoord; var y = arrycoord[i + 1]; var point = new Point(); point.x = x; point.y = y; multipoint.addPoint(point); };
var x, y, point; var multipoint = new Multipoint(map.spatialReference); for (i = 0; i < arrycoord.length; i = i + 2) { x = arrycoord; y = arrycoord[i + 1]; point = new Point(x,y); multipoint.addPoint(point); };
var x, y, point; var initColor = "#ce641d"; for (i = 0; i < arrycoord.length; i = i + 2) { x = arrycoord; y = arrycoord[i + 1]; point = new Point(x, y, new SpatialReference({ wkid: 4326 })); // it should work without reprojecting the point. If not working, then reproject it. map.graphics.add(graphic); // comment this line out if using the reproject approach //geometryService.project(point, map.spatialReference, function (newPoint) { // var graphic = new Graphic(newPoint, createSymbol(initColor)); // map.graphics.add(graphic); //}); };
var x, y, point, graphic; var symbol = createSymbol("#ce641d"); var srLatLon = new SpatialReference({ wkid: 4326 }); for (i = 0; i < arrycoord.length; i = i + 2) { x = arrycoord; y = arrycoord[i + 1]; point = new Point(x, y, srLatLon); graphic = new Graphic(point, symbol); map.graphics.add(graphic); };
var x, y, point, graphic; var symbol = createSymbol("#ce641d"); var srLatLon = new SpatialReference({ wkid: 4326 }); for (i = 0; i < arrycoord.length; i = i + 2) { x = arrycoord; y = arrycoord[i + 1]; point = new Point(x, y, srLatLon); geometryService.project(point, map.spatialReference, function (newPoint) { var graphic = new Graphic(newPoint, symbol); map.graphics.add(graphic); }); };
function createSymbol(color) { return new esri.symbol.SimpleMarkerSymbol( esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, // change to the style you like 16, // change to the size you like null, new dojo.Color(color) ); };
var strPoints; // add code to populate strPoints here. require([ "esri/map", "esri/geometry/Extent", "esri/geometry/Point", "esri/symbols/SimpleMarkerSymbol", "esri/graphic", "esri/tasks/GeometryService", "dojo/_base/array", "dojo/_base/lang", "dojo/_base/Color", "esri/layers/ArcGISDynamicMapServiceLayer", "dojo/domReady!" ], function (Map, Extent, Point, SimpleMarkerSymbol, Graphic, GeometryService, arrayUtiles, lang, Color, ArcGISDynamicMapServiceLayer) { var initialExtent = new Extent({ "xmin": 2306896.79, "ymin": 7278537, "xmax": 2710915.5, "ymax": 7674860.5, "spatialReference": { "wkid": 2953 } }); //102100, 2953 var map = new Map("NBmap", { extent: initialExtent }); var basemaplayer = new ArcGISDynamicMapServiceLayer("http://swv25orat01.gnb.ca:6080/arcgis/rest/services/WFRS/WFRS_FireSummarymxd/MapServer"); map.addLayer(basemaplayer); map.on("load", function() { map.disablePan(); map.disableScrollWheelZoom(); map.hideZoomSlider(); var geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var arrycoord = strPoints.split(","); var x, y, point; var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 16, null, new Color("#ce641d") ); for (i = 0; i < arrycoord.length; i = i + 2) { x = arrycoord; y = arrycoord[i + 1]; point = new Point(x, y); geometryService.project(point, map.spatialReference, function (newpoint) { var graphic = new Graphic(newpoint, symbol); map.graphics.add(graphic); }); }; }); });
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
