import arcpy arcpy.env.overwriteOutput = True #set number of desired cells: x=730 #set feature classes: inFC=r'C:\Path\To\Poly.shp' tempGrid=r'C:\Path\To\tempGrid.shp' #just a temporary file outFC=r'C:\Path\To\grid.shp' #final grid #set default grid variables: extent = arcpy.Describe(inFC).extent origin_coord=str(extent.XMin)+" "+str(extent.YMin) oppositeCoorner=str(extent.XMax)+" "+str(extent.YMax) y_axis_coord=str(extent.XMin)+" "+str(extent.YMin+10) number_rows=number_columns=0 geometryType = 'POLYGON' #set starting cellSize and increment: cellSize=max(float(extent.width),float(extent.height)) inc=cellSize countOutFC=0.0 #needed to start while loop #Find an appropriate cell size: while countOutFC!=x: if cellSize==inc: inc=inc/2.0 continue cell_width=cell_height=cellSize arcpy.CreateFishnet_management(tempGrid,origin_coord,y_axis_coord,cell_width,cell_height,number_rows,number_columns,oppositeCoorner,"LABELS","#",geometryType) arcpy.MakeFeatureLayer_management(tempGrid, "temp_lyr") arcpy.SelectLayerByLocation_management("temp_lyr", "INTERSECT", inFC) countOutFC=float(arcpy.GetCount_management("temp_lyr").getOutput(0)) print "Cell size: "+str(cellSize)+" Count: "+str(countOutFC) if countOutFC>x: print "Overshot..." cellSize=prevCellSize inc=inc/2.0 else: prevCellSize=cellSize cellSize-=inc cellSize=prevCellSize print '\nFound an appropriate cell size: '+str(cellSize) #Find a simplified cell size: print "\nTrying to simplify..." for i in range(len(str(cellSize))): simpCellSize=round(cellSize,i) if simpCellSize==0: continue cell_width=cell_height=simpCellSize arcpy.CreateFishnet_management(tempGrid,origin_coord,y_axis_coord,cell_width,cell_height,number_rows,number_columns,oppositeCoorner,"LABELS","#",geometryType) arcpy.MakeFeatureLayer_management(tempGrid, "temp_lyr") arcpy.SelectLayerByLocation_management("temp_lyr", "INTERSECT", inFC) countOutFC=float(arcpy.GetCount_management("temp_lyr").getOutput(0)) print "Cell size: "+str(simpCellSize)+" Count: "+str(countOutFC) if countOutFC==x: break if simpCellSize==cellSize: print "Could not easily find a simplified cell size." #rerun for last good cellsize (not simplified): cell_width=cell_height=cellSize arcpy.CreateFishnet_management(tempGrid,origin_coord,y_axis_coord,cell_width,cell_height,number_rows,number_columns,oppositeCoorner,"LABELS","#",geometryType) arcpy.MakeFeatureLayer_management(tempGrid, "temp_lyr") arcpy.SelectLayerByLocation_management("temp_lyr", "INTERSECT", inFC) else: print "A simplified cell size: "+str(simpCellSize) arcpy.Select_analysis("temp_lyr",outFC) print "Done!!!"
Hi Joshua,
Do you think it would be possible to modify your script to operate on individual polygons inside of a map instead of the map extents? I'm struggling a bit trying to figure out how to divide a map of many ~ 1 mi sections into 100 ~.1 mi sub-sections with labels in each.
Jack
Hello Jack,
I think this should work (but I didn't have a chance to test).
Let me know how it does. Good luck!
import arcpy arcpy.env.overwriteOutput = True targetLayers=['farm fields','Municipalities'] #specify all the layers you want (they must have unique names) mxdpath=r'C:\Path\To\MapDoc.mxd' #point to your mxd mxd=arcpy.mapping.MapDocument("CURRENT") lyrs=arcpy.mapping.ListLayers(mxd) dfName='Layers' #name of the data frame you want to add the new grids to for lyr in lyrs: if not lyr.name in targetLayers: continue #Skip all non-target layers #set number of desired cells: x=730 #set feature classes: inFC=lyr tempGrid=r'C:\Path\To\tempGrid.shp' #just a temporary file outFC=r'C:\Path\To\grid_'+lyr.name+'.shp' #final grid #delete tempGrid if exists: if arcpy.Exists(tempGrid): arcpy.Delete_management(tempGrid) #set default grid variables: extent = arcpy.Describe(inFC).extent origin_coord=str(extent.XMin)+" "+str(extent.YMin) oppositeCoorner=str(extent.XMax)+" "+str(extent.YMax) y_axis_coord=str(extent.XMin)+" "+str(extent.YMin+10) number_rows=number_columns=0 geometryType = 'POLYGON' #set starting cellSize and increment: cellSize=max(float(extent.width),float(extent.height)) inc=cellSize countOutFC=0.0 #needed to start while loop #Find an appropriate cell size: while countOutFC!=x: if cellSize==inc: inc=inc/2.0 continue cell_width=cell_height=cellSize arcpy.CreateFishnet_management(tempGrid,origin_coord,y_axis_coord,cell_width,cell_height,number_rows,number_columns,oppositeCoorner,"LABELS","#",geometryType) arcpy.MakeFeatureLayer_management(tempGrid, "temp_lyr") arcpy.SelectLayerByLocation_management("temp_lyr", "INTERSECT", inFC) countOutFC=float(arcpy.GetCount_management("temp_lyr").getOutput(0)) print "Cell size: "+str(cellSize)+" Count: "+str(countOutFC) if countOutFC>x: print "Overshot..." cellSize=prevCellSize inc=inc/2.0 else: prevCellSize=cellSize cellSize-=inc cellSize=prevCellSize print '\nFound an appropriate cell size: '+str(cellSize) #Find a simplified cell size: print "\nTrying to simplify..." for i in range(len(str(cellSize))): simpCellSize=round(cellSize,i) if simpCellSize==0: continue cell_width=cell_height=simpCellSize arcpy.CreateFishnet_management(tempGrid,origin_coord,y_axis_coord,cell_width,cell_height,number_rows,number_columns,oppositeCoorner,"LABELS","#",geometryType) arcpy.MakeFeatureLayer_management(tempGrid, "temp_lyr") arcpy.SelectLayerByLocation_management("temp_lyr", "INTERSECT", inFC) countOutFC=float(arcpy.GetCount_management("temp_lyr").getOutput(0)) print "Cell size: "+str(simpCellSize)+" Count: "+str(countOutFC) if countOutFC==x: break if simpCellSize==cellSize: print "Could not easily find a simplified cell size." #rerun for last good cellsize (not simplified): cell_width=cell_height=cellSize arcpy.CreateFishnet_management(tempGrid,origin_coord,y_axis_coord,cell_width,cell_height,number_rows,number_columns,oppositeCoorner,"LABELS","#",geometryType) arcpy.MakeFeatureLayer_management(tempGrid, "temp_lyr") arcpy.SelectLayerByLocation_management("temp_lyr", "INTERSECT", inFC) else: print "A simplified cell size: "+str(simpCellSize) arcpy.Select_analysis("temp_lyr",outFC) #add new data to mxd df = arcpy.mapping.ListDataFrames(mxd, dfName)[0] newlayer = arcpy.mapping.Layer(outFC) arcpy.mapping.AddLayer(df, newlayer, "AUTO_ARRANGE") print "Done!!!"
Edit (July 14, 2014): Added lines 25-27
Thanks for the reply Joshua! I didn't have much time to try this out Friday before I left the office, but on initial run, I got an error on the AddLayer call on line 94. The second argument 'addLayer' was undefined. I'll read through it again Monday morning and see if I can figure it out...I may have left something out.
Thanks again,
I had made an edit to my code shortly after posting. You must have grabbed the wrong code. Line 94 should read: arcpy.mapping.AddLayer(df, newlayer, "AUTO_ARRANGE")
Let me know if that works for you!
