Not sure if you have found a solution. You can try:1. Use Dissolve tool to unsplit lines; if there is a street name field you can use that as the Dissolve Field.2. If the resulting lines are crossing at intersections (not ending at intersections), you can use Feature To Line tool to break them at intersections.
