I try to write a function for mouse over and mouse out datagrid. Here is JSFiddle:
Edit fiddle - JSFiddle
Please help me to take a look what I need to change.
Thank you.
Hi Ken,
Thanks for highlighting that. Since i was zooming in on mouse over (which is what click does), click event seems to be doing nothing.
Below Update.
Jeff,
Since map.graphics always sits on top, i have moved your search results to selectionLayer and highligths to map.graphics, in the above fiddle.
You have a couple of errors in your code. First, when using the "dojo/on" events, the event are usually in all lower case without the "on" prefix. Use the "mouseover" event.
grid.on("mouseover", onMouseOverHandler);
Second, you're initializing a new local variable "grid" in the "showResults" function
var grid = registry.byId("grid");
but you also have a global variable "grid", which you're trying to access in the "onMouseOverHandler" function. The global variable is never set to anything since you used a local variable. It should be like this
You haven't defined "selectionLayer" anywhere.
Hi Jeff,
I have removed on from your line 127 and 128.
Is this what you are after?
Thank you for your JSFiddle. How do I change the graphic symbol to sfs that I defined at the beginning of the code?
So when mouse over the datagrid, will highlight the polygon.
I found this old link for Highlighting a graphic when the user hovers over a row
Synchronizing map and data grid interaction with the ArcGIS API for JavaScript | ArcGIS Blog
I have updated the fiddle to highlight on mouse over and out. I have changed your symbol color and style.
However, it no longer highlights the parcel when you click on the extreme left column in a row.
