public class PlotObjectSymbol : ESRI.ArcGIS.Client.Symbols.MarkerSymbol { public PlotObjectSymbol() { string template = @<ControlTemplate xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"" xmlns:x=""http://schemas.microsoft.com/winfx/2006/xaml"" > <Canvas> <Rectangle Fill=""{Binding Symbol.Symbol}"" Width=""{Binding Symbol.Size}"" Height=""{Binding Symbol.Size}"" /> <TextBlock Canvas.Top=""{Binding Symbol.Size}"" Text=""{Binding Symbol.LabelText}"" Style=""{Binding Symbol.LabelStyle}"" /> </Canvas> </ControlTemplate>"; System.IO.MemoryStream templateStream = new System.IO.MemoryStream(System.Text.UTF8Encoding.Default.GetBytes(template)); ControlTemplate = System.Windows.Markup.XamlReader.Load(templateStream) as ControlTemplate; } #region LabelText Property public string LabelText { get { return (string)base.GetValue(LabelTextProperty); } set { base.SetValue(LabelTextProperty, value); } } public static DependencyProperty LabelTextProperty = DependencyProperty.Register("LabelText", typeof(string), typeof(PlotObjectSymbol), new UIPropertyMetadata("")); #endregion ...
You can use a GraphicsLayer on top of your FeatureLayer to hold the label.
This is what I did... public class PlotObjectSymbol : ESRI.ArcGIS.Client.Symbols.MarkerSymbol { public PlotObjectSymbol() { string template = @<ControlTemplate xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"" xmlns:x=""http://schemas.microsoft.com/winfx/2006/xaml"" > <Canvas> <Rectangle Fill=""{Binding Symbol.Symbol}"" Width=""{Binding Symbol.Size}"" Height=""{Binding Symbol.Size}"" /> <TextBlock Canvas.Top=""{Binding Symbol.Size}"" Text=""{Binding Symbol.LabelText}"" Style=""{Binding Symbol.LabelStyle}"" /> </Canvas> </ControlTemplate>"; System.IO.MemoryStream templateStream = new System.IO.MemoryStream(System.Text.UTF8Encoding.Default.GetBytes(template)); ControlTemplate = System.Windows.Markup.XamlReader.Load(templateStream) as ControlTemplate; } #region LabelText Property public string LabelText { get { return (string)base.GetValue(LabelTextProperty); } set { base.SetValue(LabelTextProperty, value); } } public static DependencyProperty LabelTextProperty = DependencyProperty.Register("LabelText", typeof(string), typeof(PlotObjectSymbol), new UIPropertyMetadata("")); #endregion ... I just could not figure out how to center the text. I'm not a WPF guru.
What I do is implement IRenderer along with the PlotObjectSymbol class: like this,
ControlTemplate in App.xaml:
<ControlTemplate x:Key="cntltemplate">
<StackPanel Orientation="Horizontal">
<Image Source="{Binding Symbol.ImageSource, Converter={StaticResource StringToImageSourceConverter}}"/>
<TextBlock Text="{Binding Symbol.LabelText}" />
</StackPanel>
</ControlTemplate>
StringToImageSourceConverter is an IValueConverter implementation that converts strings to an ImageSource.
ControlTemplate = Application.Current.Resources["cntltemplate"] as ControlTemplate;
get { return (string) base.GetValue(LabelTextProperty); }
public static DependencyProperty LabelTextProperty = DependencyProperty.Register("LabelText", typeof (string), typeof (PlotObjectSymbol), new UIPropertyMetadata(string.Empty));
public string ImageSource
get { return (string)base.GetValue(ImageSourceProperty); }
set { base.SetValue(ImageSourceProperty, value); }
public static DependencyProperty ImageSourceProperty = DependencyProperty.Register("ImageSource", typeof(string), typeof(PlotObjectSymbol), new UIPropertyMetadata(string.Empty));
public class LabelRenderer : IRenderer
public Symbol GetSymbol(Graphic graphic)
var pt = new PlotObjectSymbol();
pt.LabelText = (string)graphic.Attributes["Name"];
pt.ImageSource = "Images/marker.png";
graphic.Symbol = pt;
return graphic;
Also, keep the ControlTemplate xaml simple, as this turns to slow down the rendering refresh rate.
Another thing: <esri:Map UseAcceleratedDisplay="False" .../>
