For update_row in update_cursor: geo_update_row=create a geometry object for this row's label point for search_row in search_cursor: geo_search_row=create a geometry object for this row if geo_update_row.crosses(geo_search_row) == True: update_row.something = search_row.something update_cursor.updaterow(update_row) del geo_search_row del geo_update_row
parceldesc=arcpy.Describe('parcels') parcelShapeField=parceldesc.ShapeFieldName parcel_cursor=arcpy.UpdateCursor('parcels') for parcel_row in parcel_cursor: parcel_row_shape=parcel_row.getValue(parcelShapeField) # centroid=parcel_row_shape.centroid
centroid.crosses(other geometry object)
parcel_desc=arcpy.Describe("parcels") #describe the parcels and get the shape field name parcel_shapefield=parcel_desc.ShapeFieldName flu_desc=arcpy.Describe("flu")#describe the flu and get the shape field name flu_shapefield=flu_desc.ShapeFieldName parcel_cursor=arcpy.UpdateCursor("parcels") for row in parcel_cursor: #iterate over the parcels parcel_row_shape=row.getValue(parcel_shapefield) #get the geometry object centroid=parcel_row_shape.centroid #get the centroid from the geometry object flu_cursor=arcpy.SearchCursor("flu") for flu_row in flu_cursor: #iterate over the flu flu_row_shape=flu_row.getValue(flu_shapefield) #get the geometry object if centroid.within(flu_row_shape)==True: #compare the two geometries print "RENUM: %s FLU: %s" % (parcel_row.A1RENUM, flu_row.FLU_CODE) #do some junk with the two rows del flu_cursor del parcel_cursor
# create a dictionary of centroids sr = gp.Describe(fcAU).SpatialReference cur = gp.SearchCursor(fcAU,"land = 1") row = cur.next() dAU = {} pt = gp.CreateObject("Point") while row: pt = row.shape.centroid au = row.AU_NO dAU[au] = pt row = cur.next() del row,cur print "OD records",len(dAU)
#THIS CODE LOADS A FC INTO A PYTHON DICTIONARY IN RAM (AT LEAST IT SHOULD) import arcgisscripting, sys gp = arcgisscripting.create(9.3) fc = r"D:\csny490\overlay_20100115\gis_layers\county.gdb\county" #THE INPUT FC #Process: Build a field list and a mini dictionary to look up the field order (aka index) given a field name fieldList = gp.listfields(fc) fieldIndex = 0 fieldNameDict = {} for field in fieldList: fieldNameDict[field.name] = fieldIndex fieldIndex = fieldIndex + 1 #Process: Load the fc into a dictionary fcDictionary = {} oidFieldName = gp.describe(fc).oidfieldname searchRows = gp.searchcursor(fc) searchRow = searchRows.next() while searchRow: oidFieldValue = searchRow.getvalue(oidFieldName) fcDictionary[oidFieldValue] = [] for field in fieldList: fcDictionary[oidFieldValue].append(searchRow.getvalue(field.name)) searchRow = searchRows.next() del searchRow del searchRows #Print the values of OBJECTID = 1 print fcDictionary[1] #Print the "COUNTY_NM" field value of OBJECTID = 1 print fcDictionary[1][fieldNameDict["COUNTY_NM"]] #Print the extent rectangle of OBJECTID = 1 print fcDictionary[1][fieldNameDict[shapeFieldName]].extent #Print the coordinate pairs of OBJECTID = 1 (assuming it is a single part feature) shapeObj = fcDictionary[1][fieldNameDict[shapeFieldName]] pointArray = shapeObj.getpart(0) pointObj = pointArray.next() while pointObj: print str(pointObj.x) + ", " + str(pointObj.y) pointObj = pointArray.next()
THIS CODE LOADS A FC INTO A PYTHON DICTIONARY IN RAM # http://forums.arcgis.com/threads/17956-Using-centroid-geometry-to-get-values-of-intersecting-feature#post60607 # edits by Kimo import arcgisscripting, sys import random,datetime,pprint start = datetime.datetime.now() gp = arcgisscripting.create(9.3) #THE INPUT FC fc = "d:/workspace/datetest.gdb/pineforest" #Process: Build a field list and a mini dictionary to look up the field order (aka index) given a field name fieldList = gp.listfields(fc) fieldIndex = 0 fieldNameDict = {} for field in fieldList: fieldNameDict[field.name] = fieldIndex fieldIndex = fieldIndex + 1 shapeFieldName = gp.Describe(fc).shapeFieldName # fix missing definition pprint.pprint(fieldNameDict) #Process: Load the fc into a dictionary fcDictionary = {} oidFieldName = gp.describe(fc).oidfieldname searchRows = gp.searchcursor(fc) searchRow = searchRows.next() while searchRow: oidFieldValue = searchRow.getvalue(oidFieldName) fcDictionary[oidFieldValue] = [] for field in fieldList: fcDictionary[oidFieldValue].append(searchRow.getvalue(field.name)) searchRow = searchRows.next() del searchRow,searchRows print print "Size of dictionary",len(fcDictionary) for sample in range(10): print idx = random.randint(0,len(fcDictionary)) #Print the values print fcDictionary[idx] #Print a name field value print fcDictionary[idx][fieldNameDict["LCDB1NAME"]] #Print the extent rectangle print fcDictionary[idx][fieldNameDict[shapeFieldName]].extent #Print ALL the coordinate pairs including parts and interior rings shapeObj = fcDictionary[idx][fieldNameDict[shapeFieldName]] for p in range(shapeObj.partCount): part = shapeObj.getPart(p) pnt = part.next() while pnt: print p,pnt.X,pnt.Y pnt = part.next() if not pnt: pnt = part.next() if pnt: interiorRing = True print "Hole" print "Completed",datetime.datetime.now() - start
[12139, <geoprocessing describe geometry object object at 0x16A388D8>, 66.0, u'Pine Forest - Closed Canopy', 66.0, u'Pine Forest - Closed Canopy', u'no', 64.70760971, 182.0, u'Rodney District', 16.0, u'Auckland Region', 11067.655349413637, 646803.66190707707] Pine Forest - Closed Canopy 1811685.23719998 5594544.72269999 1811781.95419998 5594599.59829999 NaN NaN NaN NaN 0 1811685.2372 5594544.9228 0 1811688.5206 5594544.9241 0 1811733.3278 5594561.747 0 1811781.9542 5594599.5983 0 1811780.0872 5594596.3042 0 1811757.3881 5594569.9774 0 1811726.5661 5594549.7439 0 1811689.9306 5594544.7227 0 1811685.2372 5594544.9228 Completed 0:00:14
