I drawed polyline in my application but I can't create a new one in line layer.
Here is my code beolow:
Here is my consol output below:
Thanks.
Problem solved when I set symbolid value,line appeared on map.Because symbolid value was null.
var feature = ArcGISRuntime.createObject("Feature");
feature.geometry = userPolyline;
feature.setAttributeValue("symbolid",'19');
offLineLayer.featureTable.addFeature(feature);
Thanks Lucas .
I suggest you try something like the following:
var feature = ArcGISRuntime.createObject("Feature"); feature.geometry = userPolyline; offlineLayer.featureTable.addFeature(feature);
I changed my code like your code but polyline cannot created.Below is console output :
KK-
Can you please post your project, or a snippet that reproduces the issue?
Luke
Here is the project below:
// Copyright 2015 ESRI
// All rights reserved under the copyright laws of the United States
// and applicable international laws, treaties, and conventions.
// You may freely redistribute and use this sample code, with or
// without modification, provided you include the original copyright
// notice and use restrictions.
// See the Sample code usage restrictions document for further information.
import QtQuick 2.0
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.1
import QtQuick.Window 2.0
import ArcGIS.Runtime.Toolkit.Dialogs 1.0
import ArcGIS.Runtime.Toolkit.Controls 1.0
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtQuick.Controls.Styles 1.2
import ArcGIS.Extras 1.0
import ArcGIS.Runtime 10.25
ApplicationWindow {
width: 800
height: 600
title: "OfflinePolygonEditing"
property double scaleFactor: System.displayScaleFactor
property bool firstPoint: true
property bool firstLinePoint: true
property bool createPoint: false
property bool isDone: false
property int polyGraphicId
property int lineGraphicId
property int fontSize: 15 * scaleFactor
property bool isOnline: true
property string featuresUrl: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Sync/WildfireSync/FeatureServer"
property string gdbPath: "~/ArcGIS/Runtime/Data/Test/offlineSample.geodatabase"
property var selectedFeatureId: null
property var xProp: null
property var yProp: null
Envelope
xMin: 1930934.6938406308 //turkey
yMin: 3850498.260784086
xMax: 5912392.6567565575
yMax: 5564737.105928443
spatialReference: mainMap.spatialReference
Map {
anchors.fill: parent
extent: sfExtent
focus: true
ArcGISTiledMapServiceLayer {
url: "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
FeatureLayer
featureTable: appWindow.isOnline ? featureServiceTable : local
selectionColor: "cyan"
GraphicsLayer {
onStatusChanged: {
if (status === Enums.MapStatusReady) {
onMouseClicked: {
if (isDone)
return;
if(createPoint)
addLinePoint(mouse.mapPoint);
else
addPoint(mouse.mapPoint);
//END MAP
GeodatabaseFeatureTable {
geodatabase: gdb.valid ? gdb : null
featureServiceLayerId: 0
GeodatabaseFeatureServiceTable {
url: featuresUrl + "/1"
ServiceInfoTask {
url: featuresUrl
onFeatureServiceInfoStatusChanged:{
if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusCompleted)
statusText.text = "Servis bilgisi alındı.Çalışma Alanı çizimini yapın";
else if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusErrored) {
statusText.text = "Error:";
generateButton.enabled = false;
cancelButton.text = "Start Over";
Feature {
Rectangle {
anchors {
fill: controlsColumn
margins: -10 * scaleFactor
color: "lightgrey"
radius: 5 * scaleFactor
border.color: "black"
opacity: 0.77
MouseArea {
onClicked: (mouse.accepted = true)
Column {
left: parent.left
top: parent.top
margins: 20 * scaleFactor
spacing: 7
Row {
spacing: 10 * scaleFactor
Button {
text: "Çalışma Alanı Sil"
enabled: false
width: generateButton.width
style: ButtonStyle {
label: Text {
text: control.text
color: control.enabled ? "black" : "grey"
horizontalAlignment: Text.AlignHCenter
onClicked: {
if (userPolygon.pathCount > 0)
userPolygon.removePath(0);
isDone = false;
firstPoint = true;
graphicsLayer.removeAllGraphics();
generateButton.enabled=false;
text: "Geodatabase Oluştur"
generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
generateGeodatabaseParameters.extent = userPolygon;
generateGeodatabaseParameters.returnAttachments = false;
statusText.text = "Starting generate geodatabase task";
geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
text: "Sync"
style: generateButton.style
enabled = false;
geodatabaseSyncTask.syncGeodatabase(gdb.syncGeodatabaseParameters, gdb);
statusText.text = "Starting sync task";
text: "İptal"
geodatabaseSyncTask.cancelJob(syncStatusInfo);
text = "İptal";
spacing: 10
Text {
text: appWindow.isOnline ? " Online " : " Offline "
color: "black"
Switch {
checked: appWindow.isOnline
onCheckedChanged: {
appWindow.isOnline = checked;
if (checked === true && Enums.GenerateStatusCompleted)
statusText.text = "Switch to Offline Mode to continue editing.";
else if (checked === false && Enums.GenerateStatusCompleted)
statusText.text = "Select a feature.";
Geodatabase {
path: geodatabaseSyncTask.geodatabasePath
onValidChanged: {
if (valid) {
var gdbtables = gdb.geodatabaseFeatureTables;
for(var i in gdbtables) {
console.log (gdbtables.featureServiceLayerName);
GeodatabaseSyncStatusInfo {
GeodatabaseSyncTask {
onGenerateStatusChanged: {
if (generateStatus === Enums.GenerateStatusCompleted)
statusText.text = geodatabasePath;
cancelButton.enabled = false;
appWindow.isOnline = false;
statusText.text = "Feature Oluştur";
createPoint= true;
else if (generateStatus === GeodatabaseSyncTask.GenerateError)
statusText.text = "Error: " + generateGeodatabaseError.message + " Code= " + generateGeodatabaseError.code.toString() + " " + generateGeodatabaseError.details;
onGeodatabaseSyncStatusInfoChanged: {
if (geodatabaseSyncStatusInfo.status === Enums.GeodatabaseStatusUploadingDelta) {
var deltaProgress = geodatabaseSyncStatusInfo.deltaUploadProgress/1000;
var deltaSize = geodatabaseSyncStatusInfo.deltaSize/1000;
statusText.text = geodatabaseSyncStatusInfo.statusString + " " + String(deltaProgress) + " of " + String(deltaSize) + " KBs...";
} else
statusText.text = geodatabaseSyncStatusInfo.statusString + "...";
if (geodatabaseSyncStatusInfo.status !== GeodatabaseSyncStatusInfo.Cancelled)
cancelButton.enabled = true;
syncStatusInfo.json = geodatabaseSyncStatusInfo.json;
onSyncStatusChanged: {
featureServiceTable.refreshFeatures();
if (syncStatus === Enums.SyncStatusCompleted) {
syncButton.enabled = false;
statusText.text = "Sync tamamlandı.Feature editlemeye devam edebilirsin.";
switchToggle.enabled = true;
if (syncStatus === Enums.SyncStatusErrored)
statusText.text = "Error: " + syncGeodatabaseError.message + " Code= " + syncGeodatabaseError.code.toString() + " " + syncGeodatabaseError.details;
GenerateGeodatabaseParameters {
fill: statusText
visible: statusText.text.length > 0
radius: 5
right: parent.right
bottom: parent.bottom
wrapMode: Text.WordWrap
Component.onCompleted:
statusText.text = "Getting service info";
serviceInfoTask.fetchFeatureServiceInfo();
Polygon {
Polyline {
Graphic {
symbol: SimpleMarkerSymbol {
color: "red"
style: Enums.SimpleMarkerSymbolStyleCircle
symbol: SimpleFillSymbol {
color: Qt.rgba(0.5, 0, 0.0, 0.25)
outline: SimpleLineSymbol {
style: Enums.SimpleLineSymbolStyleSolid
width: 2
symbol: SimpleLineSymbol {
color: "blue"
width: 5
function addPoint(mapPoint) {
var newPoint = redPointGraphic.clone();
newPoint.geometry = mapPoint;
graphicsLayer.addGraphic(newPoint);
var graphicClone = polygonGraphic.clone();
if (firstPoint) {
firstPoint = false;
userPolygon.startPath(mapPoint.x, mapPoint.y);
graphicClone.geometry = userPolygon;
polyGraphicId = graphicsLayer.addGraphic(graphicClone);
} else {
userPolygon.lineTo(mapPoint.x, mapPoint.y);
graphicsLayer.updateGraphic(polyGraphicId, graphicClone);
if (userPolygon.pointCount > 2)
silButton.enabled = true
generateButton.enabled = true;//tener ekledi
statusText.text = "Geodatabase Oluştur Buttonuna basın";//eski
function addLinePoint(mapPoint)
var newPoint = bluePointGraphic.clone();
var graphicClone;
graphicClone = blueLineGraphic.clone();
if (firstLinePoint) {
firstLinePoint = false;
userPolyline.startPath(mapPoint.x, mapPoint.y);
graphicClone.geometry = userPolyline;
lineGraphicId = graphicsLayer.addGraphic(graphicClone);
userPolyline.lineTo(mapPoint.x, mapPoint.y);
graphicsLayer.updateGraphic(lineGraphicId, graphicClone);
loadLayerColumn.visible = true;
color: "transparent"
border {
width: 0.5 * scaleFactor
visible: loadLayerColumn.visible
fill: loadLayerColumn
ColumnLayout {
visible: false
text: "Descrption özellik değerini gir"
TextField {
Layout.fillWidth: true
visible:true
text: "Özellik Değeri"
text: "Ok"
messageDialog.text = "";
loadLayerColumn.visible = false;
syncButton.enabled = true;
statusText.text = "Feature Servise düzenlemeleri kaydetme için Sync butonuna bas";
MessageDialog
title: "Error"
icon: StandardIcon.Warning
modality: Qt.WindowModal
standardButtons: StandardButton.Ok
onClicked: loadLayerColumn.visible = false
I didn't debug the whole thing, but I think the reason you are getting this failure debug message is because your feature table is for layer id "0" in the feature service, which is a point, and you are trying to add in a polyline to that feature table. It doesn't match the correct geometry, so it is rejecting the addFeature() call. I recommend switching the GeodatabaseFeatureTable and the GeodatabaseFeatureServiceTable both be 1.
-Luke
I updated the GeodatabaseFeatureTable and the GeodatabaseFeatureServiceTable both to 1, but can't create polyline.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
