Is there any method to set update event listener on feature layer? I want it to be called on every feature layer update (adding, deleting features). I do not see any valid function in the documentation.
Any help is much appreciated,
Adam
I do not believe that exists within our API. What will happen, is when you pan the map, new features should be displayed since new queries should be run on every map pan. Therefore, you do not need to refresh when new data is added from online if you are panning the map.
I would like to trigger any business logic based on feature service attribute value change or adding a new feature. This capability might be useful for developers. So, I need to create my own "listener".
Regards,
Hello nita14
I suggest that you contact your local esri distributor to log an enhancement request in addition to logging an enhancement request through the ideas website.
Alexander
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
