Is it possible to enable popup by default for each map service / feature service loaded in the layer list by Geoportal Search widget ad Add Data Widget?
We are using WAB 2.1 developer ed.
Thank you very much in advance!
Enrico
Enrico,
I did not test that. Here are the tested changes:
[install dir]\server\apps\[app#]\jimu.js\LayerInfos\LayerInfoForDefaultService.js:
_initControlPopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> mapServiceLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originOperLayer<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>layerInfo<SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> subId <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originOperLayer<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>subId<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">loadInfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">enablePopup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">500</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> enablePopup<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">(</SPAN>mapServiceLayer<SPAN class="punctuation token">.</SPAN>infoTemplates <SPAN class="operator token">&&</SPAN> mapServiceLayer<SPAN class="punctuation token">.</SPAN>infoTemplates<SPAN class="punctuation token">[</SPAN>subId<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> infoTemplates<SPAN class="punctuation token">:</SPAN> undefined <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
[install dir]\server\apps\[app#]\jimu.js\LayerInfos\LayerInfoForDefault.js:
_initControlPopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//enablePopup: this.originOperLayer.disablePopup ? false : true,</SPAN> enablePopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">?</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> infoTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// backup infoTemplate to layer.</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>_infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate<SPAN class="punctuation token">;</SPAN> aspect<SPAN class="punctuation token">.</SPAN><SPAN class="token function">after</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"setInfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>_infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo<SPAN class="punctuation token">.</SPAN>enablePopup<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">loadInfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">enablePopup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">500</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This would involve modifying a couple of the core jimu files:
[install dir]\server\apps\[app#]\jimu.js\LayerInfos\LayerInfoForDefaultService.js (lines 5 - 😎
_initControlPopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> mapServiceLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originOperLayer<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>layerInfo<SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> subId <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originOperLayer<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>subId<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// enablePopup: (mapServiceLayer.infoTemplates && mapServiceLayer.infoTemplates[subId]) ?</SPAN> <SPAN class="comment token">// true:</SPAN> <SPAN class="comment token">// false,</SPAN> enablePopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> infoTemplates<SPAN class="punctuation token">:</SPAN> undefined <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
[install dir]\server\apps\[app#]\jimu.js\LayerInfos\LayerInfoForDefault.js (lines 4 & 5):
_initControlPopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//enablePopup: this.originOperLayer.disablePopup ? false : true,</SPAN> <SPAN class="comment token">//enablePopup: this.layerObject.infoTemplate ? true: false,</SPAN> enablePopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> infoTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// backup infoTemplate to layer.</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>_infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate<SPAN class="punctuation token">;</SPAN> aspect<SPAN class="punctuation token">.</SPAN><SPAN class="token function">after</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"setInfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>_infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo<SPAN class="punctuation token">.</SPAN>enablePopup<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you Robert !
We modified the two files as you suggested: now the layer list widget opens with the "anable popup" activated but if you click on the map feature the popup doesn't appear.
Then if you manually disabe and re-anable the option, the popup appears.
Best Enrico
Thank you Robert!
now it works perfectly!
I am using WAB that is in Portal. Any way to do the same with that?
Hi Robert.
This has worked pretty well for me but I am wondering if it is possible to make this not set pop ups on basemaps. As it stands, the minute I change the basemap to something like imagery, it turns popups on for that. Depending on my zoom level, that could mean sifting through over 100 items in the popup to get what I need.
Brain,
In the LayerInfoForDefault.js make this change:
_initControlPopup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> mapServiceLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originOperLayer<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>layerInfo<SPAN class="punctuation token">.</SPAN>layerObject<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> subId <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>originOperLayer<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>subId<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">loadInfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> bmFound <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_layerInfos<SPAN class="punctuation token">.</SPAN>_finalBasemapLayerInfos<SPAN class="punctuation token">.</SPAN><SPAN class="token function">some</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>bm<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>bm<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> bmFound <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>bmFound<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">enablePopup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">500</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>controlPopupInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> enablePopup<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">(</SPAN>mapServiceLayer<SPAN class="punctuation token">.</SPAN>infoTemplates <SPAN class="operator token">&&</SPAN> mapServiceLayer<SPAN class="punctuation token">.</SPAN>infoTemplates<SPAN class="punctuation token">[</SPAN>subId<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> infoTemplates<SPAN class="punctuation token">:</SPAN> undefined <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
