I created a personal geodatabase in which I want to import GPS-derived features (with trimble gps Analyst extension). for the databese I chose geographic cordinate system in WGS84 and set the xy domain to the default values min = -400 (for both x and y) and max = 400. However, when creating a new feature dataset within the *.mdb, setting the same projection (or importing it) the resulting domain has higher maximum values for x and y (= 9006799.25474099 instead of 400).I can't see why this is happening, or how I can change it as it is not possible to define the spatial domain itself when creating the dataset, nor change it within the properties.Since the spatial domain of the database is smaller than the one of the dataset, I get an error when importing GPS derived features for postprocessing purposes. Thanks for any adviceKatharina
