private var xmlParameters:XML; public var xmlProjectParameters:XMLList; private function init():void { var xmlLoader:URLLoader = new URLLoader(); xmlLoader.load(new URLRequest("parameters.xml")); xmlLoader.addEventListener(Event.COMPLETE,init_onComplete); } private function init_onComplete(event:Event):void { var extentArray:ArrayCollection = new ArrayCollection; try { var loader:URLLoader = URLLoader(event.target) xmlParameters = new XML(loader.data) xmlProjectParameters = xmlParameters.project.(@id=="Testing") if (!(xmlParameters.extents == undefined)) { cboExtent.visible = true; for (var i:int = 0; i < xmlProjectParameters.extents.extent.length(); i++) { extentArray.addItem({label:xmlProjectParameters.extents.extent.@name.toString(), xmin: xmlProjectParameters.extents.extent.@xmin.toString(), ymin: xmlProjectParameters.extents.extent.@ymin.toString(), xmax: xmlProjectParameters.extents.extent.@xmax.toString(), ymax: xmlProjectParameters.extents.extent.@ymax.toString()}); } cboExtent.dataProvider = extentArray; }
public function cboExtent_Close():void { var extent:Extent = new Extent(Number(cboExtent.selectedItem.xmin), Number(cboExtent.selectedItem.ymin), Number(cboExtent.selectedItem.xmax), Number(cboExtent.selectedItem.ymax)) mainMap.extent = extent; }
<projects> <project id="Testing"> <extents> <extent name="Full Extent" xmin="-7389794" ymin="2023797" xmax="-7360030" ymax="2040131"/> <extent name="Zoomin" xmin="-7370000" ymin="2030000" xmax="-7365000" ymax="2035000"/> </extents> </project> </projects>
private var xmlParameters:XML; public var xmlProjectParameters:XMLList; private function init():void { var xmlLoader:URLLoader = new URLLoader(); xmlLoader.load(new URLRequest("bookmarks.xml")); xmlLoader.addEventListener(Event.COMPLETE,init_onComplete); } private function init_onComplete(event:Event):void { var extentArray:ArrayCollection = new ArrayCollection; try { var loader:URLLoader(event.target) xmlParameters = new XML(loader.data) xmlProjectParameters = xmlParameters.communities.(@id=="communities") if(!(xmlParameters.extents == undefined)) { dropdown.visible = true; for (var i:int = 0; i < xmlProjectParameters.extents.extent.length(); i++) { extentArray.addItem({label:xmlProjectParameters.extents.extent.@name.toString(), xmin: xmlProjectParameters.extents.extent.@xmin.toString(), ymin: xmlProjectParameters.extents.extent.@ymin.toString(), xmax: xmlProjectParameters.extents.extent.@xmax.toString(), ymax: xmlProjectParameters.extents.extent.@ymax.toString()}); } dropdown.dataProvider = extentArray; } } } //Zoom to your community tool public function change():void { var extent:Extent = new Extent(Number(dropdown.selectedItem.xmin), Number(dropdown.selectedItem.ymin), Number(dropdown.selectedItem.xmax), Number(dropdown.selectedItem.ymax)) myMap.extent = extent; }
<?xml version="1.0" encoding="utf-8"?> <bookmarks> <communities id="communities"> <extents> <extent name="Community #1" xmin="-13181026" ymin="4010315" xmax="-13164974" ymax="4017443"/> </extents> </communities> </bookmarks>
catch(e:Error) { Alert.show("Error: " + e.message); return; }
var loader:URLLoader = new URLLoader();
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" xmlns:container="com.esri.ags.script.*" initialize="init()" >
//the following two functions import the bookmarks.xml file private var xmlParameters:XML; public var xmlProjectParameters:XMLList; private function init():void { var xmlLoader:URLLoader = new URLLoader(); xmlLoader.load(new URLRequest("bookmarks.xml")); xmlLoader.addEventListener(Event.COMPLETE,init_onComplete); } private function init_onComplete(event:Event):void { var extentArray:ArrayCollection = new ArrayCollection; try { var loader:URLLoader = URLLoader(event.target) xmlParameters = new XML(loader.data) xmlProjectParameters = xmlParameters.communities.(@id=="communities") if (!(xmlParameters.extents == undefined)) { dropdown.visible = true; for (var i:int = 0; i < xmlProjectParameters.extents.extent.length(); i++) { extentArray.addItem({label:xmlProjectParameters.extents.extent.@name.toString(), xmin: xmlProjectParameters.extents.extent.@xmin.toString(), ymin: xmlProjectParameters.extents.extent.@ymin.toString(), xmax: xmlProjectParameters.extents.extent.@xmax.toString(), ymax: xmlProjectParameters.extents.extent.@ymax.toString()}); } dropdown.dataProvider = extentArray; } } catch(e:Error) { Alert.show("Error: " + e.message); return; } } //Zoom to your community tool public function change():void { var extent:Extent = new Extent(Number(dropdown.selectedItem.xmin), Number(dropdown.selectedItem.ymin), Number(dropdown.selectedItem.xmax), Number(dropdown.selectedItem.ymax)) myMap.extent = extent; }
private function init_onComplete(event:Event):void { var extentArray:ArrayCollection = new ArrayCollection; var loader:URLLoader = URLLoader(event.target) xmlParameters = new XML(loader.data) xmlProjectParameters = xmlParameters.communities.(@id=="communities") for (var i:int = 0; i < xmlProjectParameters.extents.extent.length(); i++) { extentArray.addItem({label:xmlProjectParameters.extents.extent.@name.toString(), xmin: xmlProjectParameters.extents.extent.@xmin.toString(), ymin: xmlProjectParameters.extents.extent.@ymin.toString(), xmax: xmlProjectParameters.extents.extent.@xmax.toString(), ymax: xmlProjectParameters.extents.extent.@ymax.toString()}); } dropdown.dataProvider = extentArray; }
Hey Jason,
Do you have the updated code for this drop down? My combobox will still not populate using the code above.
Add the features from the last choosen to an arraylist or arraycollection variable, then when u wanna go back u will pass those values to the zoom extent.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
