<div id="test" style="position:absolute; left:45px; top:65px; z-Index:999; display:block;"> <div dojoType="dijit.TitlePane" id="tp" title="Test" open="true" style="width:300px;" closable="false"> <div id="tabContainer" dojoType="dijit.layout.TabContainer" style="width:100%; height:100%"> <div id="one" dojoType="dijit.layout.ContentPane" title="Tab 1" selected="true"> Tab 1 content </div> <div id="two" dojoType="dijit.layout.ContentPane" title="Tab 2"> Tab 2 content </div> <div id="three" dojoType="dijit.layout.ContentPane" title="Tab 3"> Tab 3 content </div> </div> </div> </div>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script> <script type="text/javascript"> dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.virtualearth.VETiledLayer"); dojo.require("dijit.TitlePane"); dojo.require("esri.dijit.BasemapGallery"); dojo.require("esri.arcgis.utils"); dojo.require("dijit.layout.TabContainer"); var map = null; function init() { var initExtent = new esri.geometry.Extent({"xmin":-11727455.861413078,"ymin":4861652.558126574,"xmax":-11706340.132349325,"ymax":4871512.934775349,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{extent:initExtent}); var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(initBasemap); createBasemapGallery(); dojo.connect(dijit.byId('map'), 'resize', resizeMap); } function createBasemapGallery() { var basemapGallery = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, bingMapsKey: 'Av1bH4keF8rXBtxWOegklgWGCYYz8UGYvBhsWKuvc4Z15kT76xVFOERk8jkKEDvT', map: map }, "basemapGallery"); basemapGallery.startup(); dojo.connect(basemapGallery, "onError", function(msg) {console.log(msg)}); } function resizeMap() { //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm var resizeTimer; clearTimeout(resizeTimer); resizeTimer = setTimeout(function() { map.resize(); map.reposition(); }, 500); } //show map on load dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%;height:100%;margin:0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"></div> <div dojotype="dijit.layout.ContentPane" region="right" style="width:35%;"> <div dojoType="dijit.TitlePane" title="Switch Basemap" closable="false" open="true"> <div id="tabContainer" dojoType="dijit.layout.TabContainer" style="width:100%; height:100%"> <div id="one" dojoType="dijit.layout.ContentPane" title="Tab 1" selected="true"> Tab 1 content </div> <div id="two" dojoType="dijit.layout.ContentPane" title="Tab 2"> Tab 2 content </div> <div id="three" dojoType="dijit.layout.ContentPane" title="Tab 3"> Tab 3 content </div> </div> </div> </div> </div> </body> </html>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script> <script type="text/javascript"> dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.virtualearth.VETiledLayer"); dojo.require("dijit.TitlePane"); dojo.require("esri.dijit.BasemapGallery"); dojo.require("esri.arcgis.utils"); dojo.require("dijit.layout.TabContainer"); var map = null; function init() { var initExtent = new esri.geometry.Extent({"xmin":-11727455.861413078,"ymin":4861652.558126574,"xmax":-11706340.132349325,"ymax":4871512.934775349,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{extent:initExtent}); var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(initBasemap); createBasemapGallery(); dojo.connect(dijit.byId('map'), 'resize', resizeMap); } function createBasemapGallery() { var basemapGallery = new esri.dijit.BasemapGallery({ showArcGISBasemaps: true, bingMapsKey: 'Av1bH4keF8rXBtxWOegklgWGCYYz8UGYvBhsWKuvc4Z15kT76xVFOERk8jkKEDvT', map: map }, "basemapGallery"); basemapGallery.startup(); dojo.connect(basemapGallery, "onError", function(msg) {console.log(msg)}); } function resizeMap() { //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm var resizeTimer; clearTimeout(resizeTimer); resizeTimer = setTimeout(function() { map.resize(); map.reposition(); }, 500); } //show map on load dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%;height:100%;margin:0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> <div style="position:absolute;width:500px;height:500px; right:175px; top:10px; z-Index:999;"> <div dojoType="dijit.TitlePane" title="Switch Basemap" closable="false" open="true"> <div id="tabContainer" dojoType="dijit.layout.TabContainer" style="width:100%; height:100%"> <div id="one" dojoType="dijit.layout.ContentPane" title="Tab 1" selected="true"> Tab 1 content </div> <div id="two" dojoType="dijit.layout.ContentPane" title="Tab 2"> Tab 2 content </div> <div id="three" dojoType="dijit.layout.ContentPane" title="Tab 3"> Tab 3 content </div> </div> </div> </div> </div> </body> </html>
<div id="map" dojotype="dijit.layout.ContentPane" region="center"> <img id="loadingImg" src="images/loading.gif" style="position:absolute; z-index:100; display:none;" /> </div>
When create tabContainer, can do as below:
var tc = new TabContainer({ style: "width:100%;height:100%;", id:"myTabContainer",useMenu : false, useSlider : false, }, domConstruct.create("div"));
Baohua,
How would you actually place the tab container in your apps dom? The normal purpose of the div in the dijit constructor is place the dijit at that existing div location but since you are dynamically creating an unplaced div you are going to have issues there.
Hi Robert,
In my application I will set the tabcontainer to popup window. So the dom of the container will be attached to infoTemplate.
Then the normal process would be to query and get the dom element you are going to attach to and use that in the place portion of the dijit constructor instead of creating a new div element like you are.
