Can an ArcGIS Runtime .NET application use existing concurrent or single use licenses, similar to ArcEngine?
I've gone through the documentation. I assume the answer to my question is No, since they are using different technologies, but I'll ask again with some additional detail:
Can an ArcGIS Runtime .NET application use existing concurrent or single use licenses, similar to ArcEngine? For example, if I deploy a runtime application to a user that has ArcGIS for Dekstop installed on their machine, can they use the application without additional costs incurring?
Thanks.
Hi Joseph,
You need register a developer account for the first step. Here is the documentation about License your app—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
You're hunch is correct. No, there isn't concurrent licensing for Runtime apps, nor is there a way to leverage your Desktop license like you were able to do with Engine. As you correctly stated, these are different products and technologies.
Great question. Thanks.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
