I'm looking for some guidance on what is required and where I'd need to make modifications to a Geoprocessing widget that references a published geoprocessing service with a Feature Set input parameter that will then perform a select by location process on a separate feature service layer. The requirement workflow is:
1. Make selection in Feature Layer 1 (using the Enhanced Search Widget. Successful doing this!).
2. Select features in feature layer 2 that fall inside or intersect the selection in layer 1.
The problem is that I cannot set the Feature Set input parameter in my model and execute this from the Geoprocessing widget.
