Dim pMXDoc As IMxDocument Dim pEnv As IEnvelope Dim pGraCont As IGraphicsContainer Dim pRubberEnv As IRubberBand Dim pElem As IElement ' QI for the MXDocument interface Set pMXDoc = ThisDocument ' QI for the IGraphicsContainerSelect interface on the document's activeview Set pGraCont = pMXDoc.ActiveView ' Create a new RubberEnvelope Set pRubberEnv = New RubberEnvelope ' Return a new Envelope from the tracker object using TrackNew Set pEnv = pRubberEnv.TrackNew(pMXDoc.ActiveView.screenDisplay, Nothing) ' Create a new EnvelopeElement and set its Geometry Set pElem = New RectangleElement pElem.geometry = pEnv 'Add the new element at Z order zero pGraCont.AddElement pElem, 0 ' Refresh the activeview pMXDoc.ActiveView.Refresh
// getting Width, Height and Number of rectangles from form Dim pMXDoc As IMxDocument Dim pEnv As IEnvelope Dim pGraCont As IGraphicsContainer Dim pRubberEnv As IRubberBand Dim pElem As IElement ' DIM Coordinates Dim EnvXMin As Double Dim EnvYMin As Double EnvXMin = 425419 EnvYMin = 6011500 ' QI for the MXDocument interface Set pMXDoc = ThisDocument ' QI for the IGraphicsContainerSelect interface on the document's activeview Set pGraCont = pMXDoc.ActiveView 'create new Envelope Set pEnv = New Envelope pEnv.YMin = EnvYMin pEnv.XMin = EnvXMin pEnv.Height = EnvHeight pEnv.Width = EnvWidth For i = 1 To Numbers ' Create a new EnvelopeElement and set its Geometry Set pElem = New RectangleElement pElem.geometry = pEnv 'Add the new element at Z order zero pGraCont.AddElement pElem, 0 ' Generate Offset for next rectangle pEnv.Offset (EnvWidth / 2), 0 Next i ' Refresh the activeview pMXDoc.ActiveView.Refresh
