I am getting the following error during mobile cache synchronization. I can see about 97 features on the GPS unit, but none of them are being transferred during the synchronization. Error posting updates for wControlValve layerError posting updates for wCurbStopValve layerError posting updates for wHydrant layerError posting updates for wNetworkStructure layerError posting updates for wStructure layer [ATTACH=CONFIG]29109[/ATTACH]
Has anyone had any luck determining why Trimble Positions can't find new sessions? I am having the same problem as cfoster15 and TrentR. I can synchronize a mobile cache and get the features to import that way but I need it to recognize the sessions in order to do post-processing. I have made sure everything is in the same projection, the MXD and project are associated, etc.. I'm not sure what's wrong.
I've got a new problem and I'm trying to figure out whether it's an IT issue or something I did.
I use ArcGIS 10.2 + Trimble Positions Desktop + ArcPad extension.
Up until recently everything was running smoothly, I was able to check out data, collect data, check it in, post process it, and update my collected features to a geodatabase.
Recently, the last step in the workflow - the "Update Features" step - fails. Actually, it doesn't fail, it just doesn't work. I press the button and nothing happens. This is only occurring for one geodatabase that I use. Others will update, no problem.
Has anyone experienced this before?
The lack of a failure notification is really odd.
I recently experienced failure to update notifications when trying to update corrected polylines in a geometric network.
Is anyone aware of a workaround for this? I am planning on writing a script to create the network with the rules anyway, this problem makes the script more urgent.
Thank you, Alison Walker!! Deleting the spatial index on the sessions feature class fixed the problem I was having today with sessions not syncing.
Also, I usually have to finish sessions that are for some reason open on the Trimble before copying off the the mobile cache or I run into problems.
I have to say that this Positions software has a pretty even cost:frustration ratio (very expensive, very frustrating), it's some of the worst software I've ever had to use.
Joseph,
Sorry to hear to that you had frustrations using Trimble positions. I have
had good experiences with this software but now have moved on to ArcGIS
Mobile for Windows 7 running on Trimble Yuma 2 Tablet PC.
I am curious what exactly what you having problems with. I know Allison
Walker and she is very knowledgeable. I took some Trimble classes from her
and she was a wonderful instructor.
In kind spirit,
DIGGY
Darryl Sanchez
Realty Specialist
Real Estate Services
Bureau of Indian Affairs
Northern Cheyenne Agency
Lame Deer, Montana
Phone#: (406) 477-8286
Fax#: (406) 477-8281
*People are definitely the U.S. Government’s 20th greatest asset. It does
not make any difference whether their service is civilian or military. The
U.S. government is only as good as the people it keeps.*
-Darryl Sanchez 2013
I apologize for squeezing sour grapes in the thread, but since you asked... In terms of problems I am having with Positions, it's all over the place, similar to all the problems others have posted in this thread (exporting cache, synching cache, correcting sessions, updating features). Every time someone goes into the field with it I face a wrestling match at the front and back-end of the field session troubleshooting steps that failed for a wide variety of reasons, most unknown. Trimble has had plenty of time to get these things working better. That, combined with an overall dissatisfaction with Positions in ArcGIS Mobile workflow, 1996 GUI, and mystic error handling. Some of these things are surely a result of or made worse due to integrating with chronically sub-par ArcGIS software (esp the workflows), so I don't blame it all on Trimble.
I may just be a tough customer, but reading the rest of this thread I would think not so much.
I am having trouble when using and SDE geo database. After export, when i open the map on a GEO XT 6000 windows mobile 6.1 in ArcPAD I receive the attached error message. If I use a file geodatabase locally then I don't receive the error. I need to use SDE geodatabase in SQL.
Any ideas?
Thanks.
Hello James.
Welcome to the GPS world. You are right to say that it doesn't work. The
reason is that the technology only allows file geodatabases at this point
in the game. However, I anticipate that it will change and add other data
types.
HI Darryl,
I am pretty much 99.2% certain that I had this working up until about 4 weeks ago.
I am running Arc Desktop 10.2.1, ArcPAD 10.2 and Trimble Positions Arc-pad add-in for Windows Mobile 10.2.
I am exporting layers from Arc Desktop via the Trimble Positions for Desktop Add-in.
I am not sure what happened but one day i just started receiving this error on every thing that I exported to ArcPAD that was tied to a SQL database connection (SDE?)
Anyway if you are certain that Trimble Positions Desktop Add-IN won't export to ArcPAD correctly when using an sql database, please let me know again.
But like i said, I am pretty sure I had this going once and I don't know what changed.
Thanks!
James Hickey
Hello again,
That is just crazy. I was always told that only file geodatabases were the
only format that the GPS software worked with. I will look into it if I
find out any different I will let you know.
Check this post out James. May have solutions for you.
Cheers
Script Error 8004E37
Gold!!! thank you for finding and posting that!
This was the remedy! And here was my post back to that forum.
Fantastic!!!
I have been working on this since Monday!
Our set up is: A GeoXT 6000 running Windows Mobile 6.1, ArcPAD 10.2 for Mobile, Trimble Positions Add-in for ArcPAD 10.2.
On PC: Windows 7 64bit SP1, ArcGIS Desktop 10.2, ArcPAD 10.2 for Desktop, Trimble Positions Add-in for Desktop 10.2.
I was receiving the same SQL error:
In order to remedy this solution I had to remove the QuickField Applets from the GeoXT 6000's program files.
Located at DeviceStorage/Program Files/Arc Pad/Applets
I created a sub directory called quickFieldBackup and moved all of the Files that started with QuickField into this.
Everything works great after that!
Thank you a ton!
Hi Darryl.
This works now. See posts below for explanation. There is also a link provided by Jorge Orellana that pointed me in the right direction.
Good luck!
James
I'm having an issue with the Compatibility Testing on the Enable GNSS screen. When I run the test it tells me to "Please define a datum transformation for feature class [xyz]." I've already set a transformation in the ArcMap data frame as well as the Positions Datum Transformations dialogue (says it's for ArcPad and I'm using Mobile but figured it couldn't hurt).
I'm not aware of anyway to set a transformation to one specific feature class in ArcMap without actually modifiying the source data which isn't and option... am I missing something?
Bart
Good morning everyone...I just got everything setup with Trimble positions Desktop Add-in. I have ArcGIS 10.3 ad use TerraSync in the field on out Trimble Geo7X.
First issue is that I do not see the "GNSS enabling" option in the Desktop Administration dialog. This one has me pretty stumped
Second, I am having trouble Checking-in data collected using the generic TerraSync feature classes. I collected these data last week, prior to having our new workstation and the software. Please see the attached screenshot for the error I get when trying to check-in any SSF using the generic TerraSync features.
I can export those data to SHP files and get those opened in ArcMap, but then I am unable to correct them.....I was able to export some schema from our data model to TerraSync, and collect field data with those attributes, then check those in and successfully correct them (sort of - see #3).
Third, when I corrected the data from the test file, I was only able to select one base station, and it did not give me enough accuracy (based on what the unit was expecting). What is the best way to setup Trimble Positions for differential corrections? And, does this have something to do with not having the GNSS Enabling option?
Miles
Hi Miles,
The latest version of the Trimble Positions Desktop Add-in does not have that GNSS Enabling button anymore in the admin window. That is really only required when using the ArcGIS for Windows Mobile field software, so it was removed on purpose to try to resolve some of that confusion. If you set up a project for ArcGIS for Windows Mobile, then you will see the GNSS Enabling option in there.
On your check-in, it sounds like maybe you were collecting data in ArcPad and then trying to bring it in with the TerraSync tools? Or maybe that you had collected data in TerraSync that was just created on the handheld and not created from Positions? That won’t work to check in. In order to check in TerraSync data to Positions, it has to be checked out from Positions. If you were using ArcPad, you could use the QuickProject check-in instead.
And yes, Positions does not allow differential correction with multiple base stations the way you could in Pathfinder Office. You will only be able to correct against one base station at a time.
Hope that helps.
Alison
Thanks Alison, that does help....just wish the Positions setup documentation would have filled me in on the changes, and not instructed me to enable GNSS.
The data that I am not able to check-in was created using TerraSync, before I had any of the desktop software (or even a desktop for that matter). I will try to check-out the schema for these features and re-collect the data....sure glad I wasn't gathering tons of stuff while I waited 4 weeks for the new HP Workstation!!!
As far as differential correction accuracy....I tried using the nearest base station for my test data (a Seiler Institute one), but it continued to give me download failure warnings. Then, I tried with the GLONASS only stations, and that at least got the data corrected, but the accuracy was mostly in the 2-5m category....and the base station distance was 1.03m. Is there a way to correct the data using the base station datum or projection vs. the data's?
Thanks again.
Hello all...
I hope I am posting this in the correct place.
My organization just started using Trimble Positions with ArcMap 10.2. I am able to check out data (for use with a Trimble Geo7x), collect GNSS data, and check it back in. However, I have some projects that I created when I was getting to know Trimble Positions that I cannot remove. I wanted to clear out the Trimble Positions Desktop Administration window and remove several old projects. I keep getting this message:
Project [xyz] cannot be removed as it has active sessions.
I have already deleted the project files from my Geo---I hope that was not a mistake. I assume that those sessions are flagged as "active" somewhere in the TP Jet database, but I have no idea how to change that.
Does anyone know how to remove projects with active sessions?
Thanks a bunch!
Angela
Hold down the Control key on the keyboard while you click to remove the project and that will override that message. Hope that helps.
Sorry for the delay here. So if the Seiler station was failing to download, you might try again now that it's been a little while. Maybe it was just too soon? Those are usually pretty good I thought, and you might call Seiler directly if you can't get them to work.
The accuracy may be a result of the distance to the base station (or your receiver, and I don't see anywhere what that is). If it's really far away, you just shouldn't expect high accuracy estimates. The base station distance that you refer to above is only referring to the difference in datums and really shouldn't affect the accuracy estimates. You can go into the base provider properties when selecting a base station and on the Reference Position tab, you can choose to use the reference position from the base provider, but that's not going to improve your accuracy estimate.
The only way to know for sure that you are getting decent accuracy and that there is no datum shift occurring is to collect data on a good survey monument.
Thanks for following up Alison. I was never able to get that specific base station to download successfully....it kept giving me the same error message. I was able to use two other CORS stations fine, and when I selected "use reference position from base provider" it no longer gave me a "distance from base provider". I don't think it was an accuracy of the data issue, it was a reference datum issue, and using the base station reference should clear that up. I know I saw a video for about differential correction that explains to look for a "distance from base provider", and that if there is one, that you need to re-correct using the base station reference position.
All the stations I have been trying are less than 75km from me. The Seiler-Fox Valley station is the closest, but this is the one giving me errors when downloading. I will keep trying this station as I gather and correct new data. Will I see better accuracy from a GPS/GLONASS base station compared to GPS only?
I am however, still having issues with Trimble Positions not accepting the TerraSync Generic feature classes....but I'm sure this is because those features were not checked-out of ArcMap, and therefore Positions will not check them back in (perhaps so that it maintains data quality or conformation in some way?). A work around I have done it to create generic feature classes in my gdb, and check those out with every data dictionary...this way, I can check them in. I'll see how this goes for a while and then see if I need to change my methods.
Tanks again,
Yes, it worked!
Thanks Alison!
This worked perfectly.
I have a new question.
I am trying to use Quick Fields, for the first time. I have exported a project with a point feature class for use with ArcPad. I have opened the project in ArcPad on my pc in order to create a Quick Field that adds a sequential ID. I have turned on Quick Fields. I have gone into Design Mode. I click on the Quick Fields button and then click on the Add button.
Here is where I have a problem:
When I choose "Layer," I get this error...
I have tried closing every program on my computer except for ArcPad and I still get this error. Could this be because I am using a personal geodatabase instead of a file geodatabase?
I'm afraid I don't understand what this error means.
Any help would be appreciated.
I haven’t seen this one. Do you get the same message with other ArcPad projects? Have you tried an uninstall/reinstall?
Hi Alison,
I just got off the phone with ESRI ArcPad support and they had me move my project to a new folder location. I moved it to my desktop and it seemed to work.
Also, my apologies to everyone reading this thread as I just realized I posted an ArcPad issue on the Trimble Positions thread.
We are using Trimble Postions 10.2.1.1 with ArcGIS for Windows Mobile 10.2.1, after creating the Mobile Cache with Positions Desktop add-in 10.3.0.2.
I don't have a problem creating the mobile cache and deploying it to the field, however when I Synchronize the Mobile Cache after collecting, I get the error: "Error posting updates for TrimbleSessions layer." All of the collected features are automatically posted to the geodatabase, but we want to be able to see the point clouds associated with each feature. We have the project set up for Real-Time Corrections + Post-Processing. I can't even see that there was a session at all.
Is there a setting I need to change, or is someone else experiencing the same issue?
Here is the entire Message window:
Executing: SynchronizeMobileCache R:\GIS\GPS\xyz.mxd "R:\GIS\GPS\. . . ." UPLOAD_CHANGES DOWNLOAD_CHANGES 'User Identity for Field Collection';ControlPoints_GPS;Guardrail_points_GPS_WGS84;TrimbleSessions #
Start Time: Wed Jun 17 14:20:16 2015
Synchronizing User Identity for Field Collection layer.
Synchronized User Identity for Field Collection layer successful.
Synchronizing ControlPoints_GPS layer.
Synchronized ControlPoints_GPS layer successful.
Synchronizing Guardrail_points_GPS_WGS84 layer.
Synchronized Guardrail_points_GPS_WGS84 layer successful.
Synchronizing TrimbleSessions layer.
Succeeded at Wed Jun 17 14:20:21 2015 (Elapsed Time: 4.20 seconds)
This could be due to an issue with the spatial index. Try removing the spatial index on TrimbleSessions and re-attempting the sync.
As a note to others who read this thread, I'd suggest using your Trimble dealer and Trimble Support as your front lines for Trimble Positions questions, ahead of posting here. I don't believe this forum is monitored regularly by Trimble although you can certainly make the argument it should be.
I did remove the spatial index, but the only thing that changed originally was that I received a message stating:
"Check finished; No available sessions.
1 session in other projects remain."
I tried checking in all of the projects that I have worked on, and finally was able to see other sessions, but had no luck actually seeing the session points as we should. I just saw the polygon in the TrimbleSession Feature Class.
This morning, after shutting down PC last night, I was able to see the new Session, but I still have 8 sessions I am unable to see. They are all from last Friday in the same project. ArcGIS Mobile/Trimble Positions errored out several times and closed the program, which explains the multiple sessions. However I can't actually see the sessions as I am supposed to through the Trimble Positions Desktop add-in, I just see the features in the feature class.
FYI - I am in contact with a Support Technician also. She wanted to make sure I am checking it back in with the same MXD, which isn't the issue since I have been using the same MXD for all of the mobile caches I have created for this type of project.
Hello All,
We are having an issue with the User Identity layer in a Mobile Project not functioning properly on a certain device. Using Trimble Positions Desktop Add-in 10.3.0.2, Trimble Positions Mobile Extension (and Mobile Project Center Extension) 10.2.1.1, and ArcGIS Mobile Project Center 10.2.1.0 to create a Mobile Project using Mobile Services that were published from a Server Enterprise Geodatabase via ArcGIS for Desktop 10.2.2. The device that is having the issue is a Trimble Geo7x Handheld unit with ArcGIS for Windows Mobile 10.2.500 installed. We have setup a User ID feature class layer that is meant to record the Identity of the user that is collecting data for that current session. Whenever we open the project on the Trimble Geo7x unit, the system never prompts the user to select or create their Identity and then opens the project for data collection. If we open the project with ArcGIS for Windows Mobile (Version 10.2.1.0) on our desktops or Windows tablets (both run Windows 7) then the User ID layer works perfectly, prompting the user to select their identity or create one if they are a new user. Normally the program would not let the user continue to the project without selecting or creating their identity first. Has anyone else experienced a similar problem? Any help or suggestions would be greatly appreciated. Thank You.
Isaac... Just to remove Positions from the equation, do you get the same behavior if you create a mobile project using a mobile cache that does NOT have a TrimbleSessions layer and use that on the Windows Mobile device? You can also temporarily move the PositionsMobileExtension.ame file out of the \Program Files\ArcGIS Mobile\10.2.1\ folder to prevent the field-side extension from loading. You will get a prompt saying it can't be found as the .amp file still references it.
Hey J. - Thanks for getting back to me so quickly. I did what you suggested and created a mobile cache from the same enterprise database dataset that was used to publish the mobile services but I left out the TrimbleSessions layer. When loaded onto the Trimble Geo7x and loaded into ArcGIS for Windows Mobile it prompted me for a User Identity. So it does look like the issue seems to be stemming from the TrimbleSessions/Positions.
No worries. I'll take a look to see if something changed in a recent release. I believe it used to work although truthfully I haven't looked at that functionality in a long while.
-matt
I am running Arc 10.2 with Arcpad 10.0 so had to upgrade from the Trimble GPS Correct and Analyst to the Trimble Positions.
I am no longer able to post-process my data using an established base station data (set up by adding records from a user list acquired by our software provider). The base station information is downloaded from an ftp site but I am no longer able to download the data.
The Details are that: "The remote sever returned an error: 227 Entering Passive Mode" and the differential correction fails because "No base data file found".
I have been working with our software provider's tech support who seems to think it is something to do with our server blocking the ftp but we did not have problems prior to updating to Trimble Positions.
I thought I would post on here to see if other users encountered this problem,
Thank you,
Hi Vicky...
First step of troubleshooting would be to try copying and pasting the URL into a browser and seeing if you can download the files that way. If that works, you can always create a post processing profile that uses the local files as a workaround.
-jmm
Vicky,
If you haven't solved the Passive Mode issue, check your antivirus software, that is what was causing that error for us.
I'm not sure if this is the correct place to ask this questions but here goes...
I'm trying to check in an ssf file into ArcMap 10.2 using Trimble Position Desktop Add-in 10.3.0.2. I was able to check in two of the three projects that were transferred from the Trimble Geo 7 unit using TerraSync software. The third ssf file returns an error message.
Can someone explain what this means and how I might resolve this.
Thanks
Michael...
In all likelihood, that error is a result of using generic features in the SSF. Unfortunately, this TerraSync option isn't currently supported in the Positions workflow.
As a reminder, this thread is probably not the most efficient way of getting support for Trimble Positions. It's only monitored by Trimble on an ad-hoc basis. Your Trimble Reseller continues to be the front-line for support along with information provided on the Trimble website and on http://positionsblog.trimble.com/.
MGIS Support Options
Regards,
Matt
Matt,
I did use a few generic features while mapping. I came across a few unexpected items that needed to be collected for clarity that were not apart of my DDF. I will add a few "misc" features in my data dictionary to cover such situations.
Thanks for your help.
I made a separate "MiscGeneric" geodatabase, that has a point, line and polygon feature class, all with a bunch of fields that are similar to the data in my main geodatabase. I put them in every one of my projects and DDFs, so that when I do come across unexpected things in the field, I can at least get them marked and have some range of fields available to fill in about them.
I wish I could remove the default ones in TerraSync, but as long as you name the Generic ones different enough for you to know which one is which, then there isn't much confusion.
I am using Trimble Positions with ArcGIS 10.2.2. It has been working fine.
When I tried to do some recent post corrections, I got an error message:
“The ArcMap.exe.config file is missing the necessary modifications. Post processing cannot continue. Please re-install Trimble Positions or consult the documentation for making the changes manually.”
Would anyone know why this came up? We have recently moved our ArcGIS license manager to a new server. That is the only change I can think of that might be related.
Hi Joel,
Not sure why that would happen just from moving the license manager, but the release notes for Positions do address this error, and this fix might work for you? I’ve also found that just reinstalling Positions sometimes does the trick, and that might be easier.
During the installation process, the Trimble Positions Desktop add-in installer attempts to modify the ArcMap.exe.config file in the C:\Program Files (x86)\ArcGIS\Desktop 10.1\bin folder. Depending on permissions, this can sometimes silently fail… manually edit the ArcMap.exe.config file (using a suitable text editor, for example, Microsoft® Notepad) to make the
<!<supportedRuntime version="v4.0.30319"/>>
Hi Joel...
This would typically happen when you installed a service pack, or performed an in-place upgrade of ArcMap, as the ArcMap configuration file would get replaced. Re-installing Positions Desktop would certainly re-trigger the installer code that changes the ArcMap configuration file, but you can also make the change manually by opening up the ArcMap.exe.config file (typically in \Program Files (x86)\ArcGIS\Desktop10.2\bin) and making sure that the <startup> section contains these 2 lines:
<startup>
<supportedRuntime version="v4.0" />
<supportedRuntime version="v2.0.50727" />
</startup>
OK, I got one for the group....
Just got back in from the field. Check-in the data to ArcMap, but it gives me the error "Failed to store 10 features. Do you wish to ...(then I forget)". I click OK, and it loaded all the Point features, but none of the lines (10 lines). However, when I click on the View Features button, all the line features do show up and I can see the vertices and accuracy outlines for each.
Not sure why they aren't fully transferred or checked-in. I'll see what happens after I correct the data.
Any thoughts?
Miles...
In cases like this, I'd strongly recommend taking a look at the log file in C:\Users\<user>\AppData\Roaming\Trimble\Positions\10.1. It should give you more information about the nature of any problems on check-in. You may want to consult your Trimble support channel for deeper interpretation of any log messages. Although you can try posting specific messages here, I make no guarantees on getting a timely response.
I received some answer through my support channels....the features that are giving me issues are in Geometric Networks. I guess Positions doesn't handle these types of datasets. My work around for now is to just use my generic features in the field and cut/paste them as the networked features after they are corrected.
I have to look into geometric networks more, so I can decide if I want to leave it as-is, and continue with the work around...or, remove the geometric network so I can use the features in my projects for data collection.
I also just started getting this error out of the blue. I have tried a reinstall of Positions and to edit the config file with no luck.
Do you have any other suggestions?
Question for the group:
I have been getting started using Trimble Positions, and had managed to install and use the previous version, however, after the 10.5 update came out, I have started to try and get that version installed. I've uninstalled all of the previous trimble software (license manager, extension, etc) and reinstalled just the Trimble Positions package, but I cannot seem to get ArcMap to let me view or enable the extension anymore.
Things I've tried:
1. In ArcMap, Customize -> Add-In Manager -> Options -> Require Add-Ins to be digitally signed by trusted publisher (I've also tried the "Load all Add-ins without restrictions" but neither worked
2. Modify the arcmap.exe.config file to include these lines:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>startup</SPAN> <SPAN class="attr-name token">useLegacyV2RuntimeActivationPolicy</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>true<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>supportedRuntime</SPAN> <SPAN class="attr-name token">version</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>v4.0<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>supportedRuntime</SPAN> <SPAN class="attr-name token">version</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>v2.0.50727<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>startup</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
3. Launching license administrator and reactivating the extension software. This worked successfully but the extension still doesn't appear.
4. I've run the positions configuration tool and clicked "Test Configuration". This appears to pass with a success message (attached)
Any suggestions?
First to everyone posting here, I think support would be best served if you started a new thread for SPECIFIC issues. For those who don't know TrimblePositions Desktop supports 4 different field softwares (Terraflex, Terrasync, ArcPad, and ArcGIS for Windows Mobile). Each one of these field solutions have very different workflows, configurations, and requirements. For example, ArcGIS for Windows mobile is the only workflow that requires a TrimbleSessions layer be present in the mxd.
However, regarding the absence of the extension in ArcMap, try going into your program files folder where the add-in is installed. On my 64 bit pc it is C:\Program Files (x86)\Trimble\Trimble Positions Desktop add-In\AddIns. Close ArcMap. and then double-click the add-in to register it manually.
When starting, ArcMap will look for files with the esriAddin extension in:
ArcMap will try to extract each esriAddin file found into the assembly cache area (C:\Users\<username>\AppData\Local\ESRI\Desktop10.<version>\AssemblyCache). For each add-in a separate folder will be created named from the unique identifier (specified in a configuration file). ArcMap will then try to dynamically load all DLLs referenced in a configuration file and use specified classes as extensions, toolbars, commands and other extensible ArcMap components.
Trimble Positions Desktop installation program will try to copy the PositionsDesktopAddIn.esriAddin file to the C:\Program Files (x86)\Trimble\Trimble Positions Desktop add-In\AddIns folder and will try to create a registry subkey (option #1 above) with the folder name so that the ArcMap can load it.
Troubleshooting Trimble Positions Desktop Add-in installation
If Positions Desktop Add-In is not available in ArcMap’s Add-In Manager, the first step is to check Positions installation folder. If the PositionsDesktopAddIn.esriAddin file is not installed properly it is necessary to repeat the installation.
The next step is to check the assembly cache folder (C:\Users\<username>\AppData\Local\ESRI\Desktop10.<version>\AssemblyCache\{53B8FB5F-6061-4667-84B8-ADE5C76D6BE3})
If a folder with that path doesn’t exist, the registry key from the option 1 above should be checked. If there is no a correct subkey the Positions Desktop Add-in installation can be fixed using one of the following methods:
After one of those steps is done, ArcMap should be restarted and Add-In Manager can be used to confirm if Positions Desktop Add-in is properly loaded.
