Hi Kent,Take a look at the following link about updating statistics.You should update statistics before and after a compress operation, after you add or remove topology rules, and after you have finished importing, loading, or copying data into an ArcSDE geodatabase. Here is a link about rebuilding indexes. If you are using SQL Server Enterprise edition, refer to the following KB article on how to rebuild indexes.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
