Hallo, <\/P>
Ich lade einen Utility Isolation Trace<\/A> herunter und habe ihn mit den Beispieldaten konfiguriert, und es funktioniert sehr gut, aber wenn ich versuche, mein Wassernetz mit einer anderen Projektion WGS1984 UTM37 in die Datenbank hinzuzufügen, funktioniert es nicht.<\/P><\/P>Bitte erklären Sie mir, ob ich diese Anwendung für mein eigenes geometrisches Netzwerk konfigurieren kann?<\/P>mmiller-esristaff<\/A> bitte helfen Sie mir<\/P><\/BODY><\/HTML>
<\/P>
Using your data, I was able to get it to working by changing the InputeGDB and Output Coordinate System(2) in the model. I set Output Coordinate System(2) using the feature dataset in the GDB you provided.
Thanks for answer dear Michael
No you sample data is working well, but i want add my data from sql SDE data base, my features is in different projection wgs1984 utm37 and it is problem, that i could not configured GP trace tool with my projection.
when i am executing gp tools error is same that output coordinate system is error and unknown extent.
i need configuret GP model builder, how i can configured i need some manuals
I am attached my water geometric network if you can please check it and can you help me configure GP Isolate Trace?
ERROR LOG
ERROR 999999: Error executing function.invalid extent for output coordinate systemFailed to execute (Project Flags).Failed at Thu Sep 29 22:46:34 2016 (Elapsed Time: 0.20 seconds)Failed to execute (IsolationTrace).Failed at Thu Sep 29 22:46:35 2016 (Elapsed Time: 1.38 seconds)
What is not working? Are the flags being snapped? Sometimes you need to delete and re-add the featureset inputs. Did you adjust steps that project the data to your local coordinate system? Also, try deleting the Trace Geometric Network tool and re-add to ensure it is looking at the correct data.
