buffer = arcpy.Buffer_analysis(roads, "in_memory/buffer", "1000 Feet")
Hi folksI'm having issues troubleshooting an error message while trying to set my buffer parameters.The intention is to create a selection criteria on an ArcGIS Map to generate areas that are 1000 feet around any major roads.I have already defined roads as a variable, and the following is the tool parameter that I'm trying to input, which sets the optional dissolve parameter to ALL , so that overlapping buffers are dissolved:buffer = arcpy.Buffer_analysis(roads, "in_memory/buffer", "1000 Feet", "", "", "ALL")Now I keep getting an error message with the word buffer highlighted but I don't know what's wrong. Also, as I type the word buffer in the IDLE screen it turns purple. Does this mean it has some kind of internal definition or something?
