My widget buttons 1 and 2 are overlapping each other in WAB (Image below). How do I fix this in the code?
Thanks
Attached image?...
Hmmm...I've attached now
Joe,
Sorry you have cropped you image down so far I can not tell what the on screen widget placeholder is overlapping.
That huge gap between buttons is my problem. Button 1 and 2 are on top of each other where the swap icon is. I can only have 3 widgets
post your main config.json
Config.json attached. Found in C:\arcgis-web-appbuilder-2.8\WebAppBuilderForArcGIS\server\apps\3
So it looks like you have been making some manual edits to your config.json.
Here is the onscreen widget placeholder section fixed.
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"position"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"left"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">55</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">45</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"relativeTo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"placeholderIndex"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"_25"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"version"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"2.8"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"closeable"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"uri"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"widgets/LayerToggleButton/Widget"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"LayerToggleButton"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"icon"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"configs\\LayerToggleButton\\icon__25.png"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"config"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"configs/LayerToggleButton/config__25.json"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"position"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"left"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">105</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">45</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"relativeTo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"placeholderIndex"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"_26"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"version"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"2.8"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"closeable"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"uri"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"position"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"left"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">155</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">45</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"relativeTo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"placeholderIndex"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"_27"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"label"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Query requests by tenant"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"version"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"2.8"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"closeable"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"uri"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"widgets/Query/Widget"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"config"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"configs/Query/config__27.json"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"position"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"left"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">205</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">45</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"relativeTo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"placeholderIndex"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"_28"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"label"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Query request type"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"version"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"2.8"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"closeable"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"uri"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"widgets/Query/Widget"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"config"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"configs/Query/config__28.json"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
