Hi all
I want to add two tables in geodatabase view (see attached). Those two table can not be related (attributes tables)
I am struggling with the SQL statement
Thanks
Without a join? Something like this in SQL maybe?
SET QUOTED_IDENTIFIER ON GO SET ANSI_NULLS ON GO if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[v_gis_view_test]') and OBJECTPROPERTY(id, N'IsView') = 1) drop view [dbo].[v_gis_view_test] GO ---------------------------------------------------------------------------------------------------------------- /* COMMENTS... */ ---------------------------------------------------------------------------------------------------------------- CREATE VIEW dbo.v_gis_view_test AS SELECT table1.f1, table1.f2, table1.f3 FROM dbo.theTableOne table1 UNION SELECT table2.f1, table2.f2, table2.f3 FROM dbo.theTableTwo table2 GO SET QUOTED_IDENTIFIER OFF GO SET ANSI_NULLS ON GO
In ArcGIS, I believe you would just add the view name, "v_gis_view_test" in this case, in the name box, and the select clauses in the expression box. Is this what you're looking to do?
I tried in arcCatalog with New/View with the following code:
SELECT
gkmigeodatabase.NCR.AB_WetlandsGrid_25km.OBJECTID,
gkmigeodatabase.NCR.AB_WetlandsGrid_25km.PageName,
gkmigeodatabase.NCR.AB_WetlandsGrid_25km.percentage
FROM
UNION
gkmigeodatabase.NCR.BC_WetlandsGrid_25km.OBJECTID,
gkmigeodatabase.NCR.BC_WetlandsGrid_25km.PageName,
gkmigeodatabase.NCR.BC_WetlandsGrid_25km.percentage
The problem is that no geometry is loaded
After, I right click on my view to load data:
unfortunately, I got this error
I want notace that my feature classes have exactly the same schema
thanks for your help
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
