Sub WhateverName() [INDENT] Try Dim pMxDoc As IMxDocument = DirectCast(m_app.document, IMxDocument) Dim pMap As IMap = pMxDoc.FocusMap Dim pMapDoc As IMapDocument = pMap Dim mxdPathName As String mxdPathName = strDefaultWorkspace & "\" & frmWSIn.txtMapDocName.Text pMapDoc.SaveAs(mxdPathName) Catch ex as Exception Msgbox(ex.Message) End Try [/INDENT] End Sub
//Dim pMxDoc As IMxDocument = DirectCast(m_app.document, IMxDocument) IMxDocument mxDocument = ArcMap.Document; //Dim pMap As IMap = pMxDoc.FocusMap IMap map = mxDocument.FocusMap; //Dim pMapDoc As IMapDocument = pMap IMapDocument mapDocument = map as IMapDocument; //Dim mxdPathName As String //mxdPathName = strDefaultWorkspace & "\" & frmWSIn.txtMapDocName.Text string mxdPathName = "C:/temp/testsave.mxd"; //pMapDoc.SaveAs(mxdPathName) mapDocument.SaveAs(mxdPathName, false, false);
IMapDocument mapDocument = new MapDocumentClass(); mapDocument.Open("C:/temp/mymap.mxd", ""); string mxdPathName = "C:/temp/testsave.mxd"; mapDocument.SaveAs(mxdPathName, false, false);
IMapDocument mapDocument = (IMapDocument)ArcMap.Document; string mxdPathName = "C:/temp/testsave.mxd"; mapDocument.SaveAs(mxdPathName, false, false);
// Load the current map document's file into a new IMapDocument IMapDocument mapDocument = new MapDocumentClass(); mapDocument.Open(((IDocumentInfo2)ArcMap.Document).Path, ""); // Replace the contents with the current contents mapDocument.ReplaceContents((IMxdContents)ArcMap.Document.PageLayout); // Save to a different file mapDocument.SaveAs("C:/temp/testsave.mxd", mapDocument.UsesRelativePaths, false); mapDocument.Close();
// Load the current map document's file into a new IMapDocument Dim pDocInfo as IDocumentInfo2 = DirectCast(m_app.Document, IDocumentInfo2) Dim pCurDocPath as String = pDocInfo.Path Dim pMapDocument as IMapDocument = New MapDocumentClass() pMapDocument.Open(pCurDocPath, String.Empty) // Replace the contents with the current contents pMapDocument .ReplaceContents(CType(m_app.Document.PageLayout, IMxdContents)) // Save to a different file mxdPathName As String = strDefaultWorkspace & "\" & frmWSIn.txtMapDocName.Text pMapDocument.SaveAs(mxdPathName, pMapDocument.UsesRelativePaths, False) pMapDocument.Close()
Public Sub SaveDoc() Try Dim pMxDoc As IMxDocument = m_application.Document Dim pMap As IMap = pMxDoc.FocusMap Dim pmxdPathName As String Dim pMapDoc As IMapDocument = New MapDocument Dim pMxdContents As IMxdContents = pMap pmxdPathName = "C:\Documents and Settings\ruchira.welikala\Desktop\GIS Stuff\PracticeShapefiles\TestMXD" & Math.Round(Date.Now.Millisecond, 3) & ".mxd" pMapDoc.[New](pmxdPathName) pMapDoc.ReplaceContents(pMxdContents) pMapDoc.SetActiveView(pMxDoc.ActiveView) pMapDoc.Save(True, False) Catch ex As Exception MsgBox(ex.Message) End Try End Sub
// This successfully saves a copy of the current document to a new location (C#): ArcMap.Application.SaveAsDocument(@C:\temp\testsaveIapp.mxd, true);
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
