I have a Feature Service create here: http://maps.decaturil.gov/arcgis/rest/services/IvFeature/FeatureServer
And I wanted to add it to my map. But based on the documentation, it looks like I can only add one feature layer at a time. Is this correct?
Never mind. I got this one figured out. I don't need a feature service. My dynamic service is now working.
Chris,
So the question is why are you trying to load the layers from the FeatureServer and not the MapServer? The only reason I can think of is that you want to edit each of those layers (that doesn't sound right)...
I was having trouble figuring out how to make the measurement example with a dynamic map service work, so I tried publishing a feature service and using it like a dynamic map service. Apparently that won't work. I tried this because I had not gotten a response on how to make the dynamic map service work.
Here is my code using a dynamic map service:
<!DOCTYPE html>
<html>
<head>
<title>Create a Map</title>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body, #mapDiv
padding:0;
margin:0;
height:100%;
width:100%;
#titlePane
width:240px;
position:absolute;
right:20px;
top:10px;
z-index:999;
.soria .dijitTitlePaneTitle {
background: #fff;
font-weight:600;
border: none;
border-bottom:solid 1px #29201A;
border-top:solid 1px #29201A;
.soria .dijitTitlePaneTitleHover
background:#eee;
.soria .dijitTitlePaneTitleActive
background:#808775;
.soria .dijitTitlePaneContentOuter
border-right: none;
border-bottom: none;
border-left: none;
</style>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
var map;
require(["esri/map", "esri/config",
"dojo/parser",
"esri/renderers/SimpleRenderer",
"esri/Color",
"esri/dijit/Measurement",
"esri/dijit/Scalebar",
"esri/geometry/Extent",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/LayerDrawingOptions",
"esri/SnappingManager",
"esri/sniff",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/tasks/GeometryService",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/form/CheckBox",
"dijit/TitlePane",
"dojo/dom",
"dojo/keys",
"dojo/on",
"dojo/domReady!"], function (Map, esriConfig, parser, SimpleRenderer, Color, Measurement, Scalebar, Extent,
ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, LayerDrawingOptions, SnappingManager,
has, SimpleFillSymbol, SimpleLineSymbol, GeometryService, dom, keys, on
parser.parse();
// set custom extent
var initialExtent = new Extent({
"xmin": 777229.03,
"ymin": 1133467.92,
"xmax": 848340.14,
"ymax": 1185634.58,
"spatialReference": {
"wkid": 3435
// create map and set slider style to small
map = new Map("mapDiv", {
showAttribution: false,
sliderStyle: "small",
extent: initialExtent
// add imagery
var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
map.addLayer(tiled);
// set operational layers
var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
// add operational layers
map.addLayer(operationalLayer);
// declare geometry service
esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
// start measurement tool - the current layer we are measuring is the operational layer
// error follows this line
var layerDrawingOptions = [];
var layerDrawingOption = new LayerDrawingOptions();
var sfs = new SimpleFillSymbol(
"solid",
new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
null
layerDrawingOption.renderer = new SimpleRenderer(sfs);
// change 1 to the layer index that you want to modify:
layerDrawingOptions[1] = layerDrawingOption;
dynamicData.setLayerDrawingOptions(layerDrawingOptions);
//dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
var snapManager = map.enableSnapping({
snapKey: has("mac") ? keys.META : keys.CTRL
var layerInfos = [{
layer: operationalLayer
snapManager.setLayerInfos(layerInfos);
var measurement = new Measurement({
map: map
}, dom.byId("measurementDiv"));
measurement.startup();
// end measurement tool
</script>
</head>
<body class="soria">
<div id="mapDiv"></div>
<div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closeable:'false',open:'false'">
<div id="measurementDiv"></div>
<span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
</div>
</body>
</html>
So did you also figure out your misaligned requires and your trying to use class soria yet not adding the proper link for that css?
Yes, I got the requires aligned and realized the soria weren't referenced when the arrows weren't in my widget. Can't believe I didn't update my CSS.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
