Jarom,In desktop, you create a local copy for editing, then check it back in. See attached image.Thanks,Mike
Mike,I get no such option to create a local copy. Perhaps I am not adding the data correctly. Right now, I am dragging in my web map listed under My Hosted Services in ArcCatalog. Please look at the attachment. These are the only options that I get. Do I need ArcGIS for Server to have this functionality?Thanks!
Not through this new option, at least not yet. Desktop currently has it's own workflow for creating a local copy for editing. This, however, is a last edit in wins process, not synchronization.Thanks,Mike
Ahhhh, you are very observant. http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q000000n0000000"If your editors will occasionally be disconnected from the network, check Enable Sync. This allows your editors to get the latest updates to features at the time they connect. Any edits they made to features while disconnected will also be applied at the time they connect. Sync is currently only supported in ArcGIS for Windows Mobile."This is an ongoing development effort and over time more and more client apps will support it.Thanks,Mike
