This is my first time adding text to a map. After reading the online help, annotation seems to be how I shouljd go about it. I am drawing a small map of a downtown area and I am trying to label the streets. Setting the font size at 6 points still has it way too big for my map. See attached. I would appreciate any tips.
I'd still download the necessary TIGER data, then use the labeling manager to label your roads. Change the symbology to transparent. Voila.
Good luck!
Rather than adding text in that fashion, try reading the sections on labelling. With the standard and Maplex options, you have greater flexibility and control
Labeling basics—ArcGIS Pro | ArcGIS Desktop
Aren't labels associated with a features based on field names? I want to place names on the streets and those are between features.
Don't you have a street file that you could label?
No. What is a street file?
I do not. The streets are the negative space between my block polygons. I suppose I could create polygons between those for the labeling. It seems like that may be the solution that I need to use.
You're making work for yourself...streets data are fairly common
Start by looking here, and if these are insufficient I'd also suggest looking for your county or municipal data portal. Let us know, please!
I do have road edges from my county, but I didn't like it. It also included building outlines and some other "errors" I didn't care for. So I decided to create my street network by tracing the parcel data. I'm not doing a large area, so adding those additional polygons won't be too much work. But you could very well be right that this isn't the best way to draw my map. At least I am learning, though. The jpg attached to my original post shows the extent to which I am drawing.
That's a good idea. I'll have to make some corrections, but I am going to try that. Thanks!
Is there a way to indicate the street is a one way using this method?
You're asking about network flow now. Your Streets data would need to have a To field and a From field along with known points in order for this to work. I believe Esri's streets network that's leveraged in the Business Analyst data do have this type of information, but I'm fairy certain the TIGER data does not.
I will now go learn about the draw tool. Thanks for the insight.
In Pro the workflow is to create your layout, then use the Insert -> Graphics:
You can modify the line feature to include arrowheads.
