Hello.
I'm developing sceneView application and i can't see basemaps when i debugging my project on localhost (pressing F5). Because CORS policy blocking my localhost. But i see no error when i published my project.
I tried to add
esriConfig.request.corsDetection = false;
But doesn't worked.
AccessTo image at "https://myproxyserver/resource-proxy/proxy.ashx?http://myserver.com/myservice/3/5/1.jpg" from origin "https://localhost:44300" has been blocked by CORS policy: No "Access-Contol-Allow-Origin" header is present on the requested ressource. Origin "https://localhost:44300" is therefore not allowed access
Thanks inadvance.
Tuba,
You really need to get out of the habit of using localhost. You should use your machine name instead and then make sure you have added your machine name to the proxy.config serverUrls.
thanks for the answer.
ye you're right.
I tried to add below codes into my javascript file
urlUtils.addProxyRule ({ urlPrefix: "https://mymachinename", proxyUrl: "https:proxrserver/proxy.ashx"});
and into proxy.config file
<serverUrl url="https://mymachinename" matchAll="true" />
and i changed to Project URL from VB.NET Project Properties with "https://mymachinename"
doesn't worked. same error.
You have to add the port number to the url or else it is seen as a different server. https://mymachinename:44300 needs to be added to the proxy rule and proxy.config
Hi Robert,
i've defined 44300 port as https from IIS manager. mymachinename is my local IIS name not different server.
JS file
urlUtils.addProxyRule ({ urlPrefix: "https://mymachinename:44300", proxyUrl: "https:proxrserver/proxy.ashx"});
proxy.config file
<serverUrl url="https://mymachinename:44300" matchAll="true" />
still getting same error. I just seeing empty globe in sceneview.
Can you post the error again now that you have made these changes? I just can not understand how you would be getting the same exact error now.
Hello,
I'm getting this error on program startup (with sceneview). I'm seeing only white sceneview. "MyCustomTileMap" is my basemap and i can access from MapView without error. This error occurs when i switch to 3D.
Access to image at "http://myproxyserver/mydir/proxy.ashx?http://mymapserver/Maps/MyCustomTileMap/1/2/3.jpg" from Origin "http://mymachinename" has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin "http://mymachinename" is therefore not allowed access.
Notice that the error is using the http protocol not https you added to the proxy. Also the error does not show a port number.
sorry my bad. all adresses started with https not http. just written wrong here. I tried to run my application with 44300 portnumber and added into proxy.config with port. Still getting same error.
Access to image at "https://myproxyserver/mydir/proxy.ashx?http://mymapserver/Maps/MyCustomTileMap/1/2/3.jpg" from Origin "https://mymachinename" has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin "https://mymachinename" is therefore not allowed access.
So are you also forgetting to add the port number when you are editing the error message to post here?.. You should add the serverURL with http and https and the port and without the port for testing in the proxy.config and proxy rules.
Yes Exactly
My machine name is "goldone".
proxy.config
<serverUrl URL="http://goldone" matchAll="true" /><serverUrl URL="http://goldone:44300" matchAll="true" /><serverUrl URL="https://goldone" matchAll="true" /><serverUrl URL="https://goldone:44300" matchAll="true" />
urlUtils.addProxyRule ({ urlPrefix: "http://goldone", proxyUrl: "https://proxrserver/proxy.ashx"});urlUtils.addProxyRule ({ urlPrefix: "http://goldone:44300", proxyUrl: "https://proxrserver/proxy.ashx"});urlUtils.addProxyRule ({ urlPrefix: "https://goldone", proxyUrl: "https://proxrserver/proxy.ashx"});urlUtils.addProxyRule ({ urlPrefix: "https://goldone:44300", proxyUrl: "https://proxrserver/proxy.ashx"});
have i do something another this
My application running from VB.NET (with F5) starting as "https://goldone:44300"
Tuba, that looks good for the proxy rules now in the proxy.config you need to do the same for the serverURLs
Robert,
This is my proxy.config file which in same directory with proxy.ashx
<serverUrl url="http://goldone" matchAll="true" /><serverUrl url="http://goldone:44300" matchAll="true" /><serverUrl url="https://goldone" matchAll="true" /><serverUrl url="https://goldone:44300" matchAll="true" />
I found the problem. My proxy file is not on my machine. I 've added Some variables to my proxy machine's http response headers.
My fault is that i searching error on my machine since 2 days. Actually error was in proxy machine's proxy web application configuration.
My problem solved and working now. I'm happy.
Thank you again for all help.
Here is the picture where i added variables
